Post by derail on Dec 18, 2013 14:35:22 GMT -6
sorry it took so long to get back on here with this info. I can,t get a camera right now so I'll try to tell you what my wire color's are. From the stator A white wire, A yellow /red stripe wire, which changes to green/yellow at first plug, A black wire, A Green/white wire A black/red wire that changes to red/black stripe at first connector, A white wire, A green/white stripe wire, And A white/red stripe that changes to red/yellow at first connection. Then the racing CDI has a red/black wire, A red/white wire, A black wire, A black/ white stripe wire, A orange wire, A dark green wire with a white/green stripe wirw spliced to it. The wiring harness to the cdi box has A red/yellow stripe wire, A red/black stripe wire A orange wire, A black wire, A dark green wire, A green/white stripe wire. ARE YOU CONFUSED YET I sure am. I hope this will help. Thank you very much for any help
Post by derail on Nov 22, 2013 18:24:52 GMT -6
This scoot has a small bulb in the bottom of the headlight? Does it burn when it starts? It has a brown wire and a black wire to it. does not light up when cranking like the other bulbs do. It also has a big bulb for the headlight that works. Any ideas on this ?? Thanks again for all the HELP
Post by derail on Nov 22, 2013 16:28:34 GMT -6
tried to take pictures with my webcam with no luck maybe tomorrow i can borrow a good camera thank you very much
Post by derail on Nov 22, 2013 5:03:24 GMT -6
I do not have any of these color wires to the alarm I tried to unplug the alarm that did not work, I pluged the alarm back up, and removed the fuse, That did not work either?
Could it still be cdi wire hookup to the racing cdi???Thanks very much for your help
Post by derail on Nov 21, 2013 17:17:38 GMT -6
I have tried everything. I have the rear brake lever weged on, and the brake light comes on when you crank it. Also the green light on the racing cdi flashes when you crank it?
Post by derail on Nov 21, 2013 3:52:15 GMT -6
Thanks I have heard of having to put jumper wires to 4 terminals on plug for the alarm to make it run?
Post by derail on Nov 13, 2013 0:26:35 GMT -6
When I bought this scooter the cdi was missing. I bought a new racing cdi.But the colors of the wires were all diferent. And I canot get any spark. This scoot has a alarm system and it don't look to be in very good shape. Rusty connections and etc. could this be my problem of no spark? and if so could i just unplug it?
Post by derail on Oct 15, 2013 15:17:42 GMT -6
the best way i've found is to remove the spark plug feed some rope in there turn the motor till the rope stops it then you can take the nut off variator. then put back on same way. then pull rope out of cylinder, and put plug back in ! worked good for me THIS WAS ON A 2STROKE MOTOR DON'T TRY THIS WITH A 4 STROKE MOTOR THE ROPE CAN GET CAUGHT IN THE VALVES AND BE A BIG PROBLEM Derail
