Post by scooterdroid on Dec 28, 2013 11:42:53 GMT -6
well i guess recommending this in the alfa stage of its trial is pompous. because I dont actually know what is happening in the variator. But I can Attest and say its performance is much greater than stock. but with any upgrade can create extensive wear where there was none. Or catastrophic damage. My scooter was very cheap to obtain so im just experimenting. my 320# brother rides it and hes says " damn that lil thing can move" lol I believe I hit about 50++ mph down hill.
Post by scooterdroid on Dec 27, 2013 12:23:21 GMT -6
No. There is six single slots for the rollers. So each roller has its own bay/cavity to slide in.
Post by scooterdroid on Dec 24, 2013 11:50:37 GMT -6
Yea I ride about half throttle untill it shifts. then I go full. Its much funner and much quicker all around. Im actually impressed by this 50cc...I would recommend to anyone with a good running but slugish bike. Ill post the longevity or wear when I encounter it if I do....Thanks for the input.
Post by scooterdroid on Dec 23, 2013 19:47:25 GMT -6
So they are 9g weights. So 27g. And I have inspected the vairiator and transmission area all looks good. But is still ringing/vibrating only on acceleration for just on second. sounded a little worse when i let my big friend ride it. but the same with me. And was defiantly not making the sound before I removed the other weights.
Post by scooterdroid on Dec 22, 2013 22:09:12 GMT -6
Ok....well It worked!!! quite well also im going to say twice if not more power. Not reving to high either. But a sound coming from cvt area sound like metal squeaking or the belt squeaking and accompanied by a ringing rattle like a bell. Only at very low rpm but not at idle only during acceleration for like 1 second. then as i accelerate its smooth threw the whole bottom and top end. 43 mph max today.... using only three rollers.....
Post by scooterdroid on Dec 22, 2013 22:07:47 GMT -6
how do I post pics here easily???
Post by scooterdroid on Dec 22, 2013 22:04:47 GMT -6
tail light
by: scooterdroid - Dec 22, 2013 10:52:20 GMT -6
Post by scooterdroid on Dec 22, 2013 10:52:20 GMT -6
So I have a craig list scooter I got for 150$. And the tail light is on all the time? Even with the kill switch in the off position. There is no key. and the wires(red n black) that were to the key lock/mehcanisum are striped and connected together. Only way to turn off the light is to disconnect the battery. Should i put a switch on the key wires?
Post by scooterdroid on Dec 21, 2013 20:56:47 GMT -6
hummm...well im super curious what will happen. But I think ima just play around with it. i have a few different roller sets ima mix and match see what i get. And yea im only 150lbs rider..
Post by scooterdroid on Dec 21, 2013 19:51:12 GMT -6
Anyone object? Im now worried about the clutch and bell blowing up? I did run 6g on another stock set up. 6gx6rollers=36g....12gx3rollers=36g?
Post by scooterdroid on Dec 21, 2013 19:28:28 GMT -6
10-4....Ill post my happenings.
Post by scooterdroid on Dec 21, 2013 18:53:41 GMT -6
Do you by chance know a ball park rage of what might be in my stock roketa Sicily 50cc from 2008.
Post by scooterdroid on Dec 21, 2013 18:49:57 GMT -6
ok, ty
Post by scooterdroid on Dec 21, 2013 18:31:38 GMT -6
I have a 50cc qmb motor. With standard variator and rollers. It is sluggish or slow not reving very high before the CVT starts to shift. I was wondering can I just run with three rollers in my variator to let it rev a bit higher before the shift? Or do I need all six for proper performance? and dose roller color indicate weight? Also when on center stand it will rev very high so I know its capable...
