Post by jmabrao on Nov 3, 2010 14:20:38 GMT -6
Tried the boric acid. No go exactly what needs to be greased in the clutch?
Post by jmabrao on Nov 1, 2010 23:03:28 GMT -6
I will have to try that tomorrow, the squeaking is incredibly embarassing. And its weird that the stalling only happens when I start it normally, if I start it with the remote start it runs just fine. And that bog only happens sometimes. It's weird, and no I have not changed out the vacuum and fuel lines.
Post by jmabrao on Nov 1, 2010 16:21:33 GMT -6
Oh and one more issue idling at a long stop light when it turns green I give it gas and it bogs out I have a feeling that the big may be caused by the crummy vacuum fuel pump
Post by jmabrao on Nov 1, 2010 15:39:16 GMT -6
as soon as the clutch engages fully and stops slipping the squeak is gone.
Post by jmabrao on Nov 1, 2010 13:52:59 GMT -6
It goes away as the clutch engages I changed all the fluids so the fluids are good
Post by jmabrao on Nov 1, 2010 13:35:10 GMT -6
Thanks for the quick replies. I have already adjusted the valves so that's ruled out. But the funny thing is that it doesn't cut out at all when I start it with the remote starter. Any ideas on the squeaky clutch engagement
Post by jmabrao on Nov 1, 2010 10:32:00 GMT -6
Hello all first time poster here. I bought my roketa from a gentleman at about 600 miles. have since put about 1000 miles on it and I am loving it aside from these two issues. For one on take off the clutch squeaks bloody murder, and for two every once in awhile the engine will have like random cutting out. I had a problem where I had the key turned to the on position and it would turn over but not start, than I used the remote start and it fired right up. As for the clutch I have taken the bell off and sanded all the surfaces down, and cleaned it all out to no avail, the squeak returns almost immediately. I am completely stumped on the cutting out problem though.
Any ideas guys?
Thank your for your help Joel
