Post by chappco on Nov 30, 2010 13:29:49 GMT -6
Need some help and see some messages from April. My choke does not work, and it is a new carb and choke. I know that it needs power and I think it comes from the armature yellow thru a control box, which I "think" is just a 10.2 ohm 5 watt load resistor in case the coil on the auto enrichener shorts, the source will not blow. Can anyone tell me is this is correct, and if so, can I just hook it up to the battery using the ballast resistor. The scoot runs great, just hard to start after cold, or overnight sit. I have to blip the throttle about 3 or 4 times to get it started and let it warm before any gas is given. Once warmed it runs great. Thanks for any help you may give me. Regards Pat
