Post by blazef20 on Jan 20, 2011 21:51:28 GMT -6
wow mflorek. did it a couple times to my truck put a big dent in the side of it. i really havent had time for the gy6. snow sux!!!! after i put the buggy in the side of the truck i put it on blocks (rear end). But im inclined to belive the motor did not seize. The motor is always turning its got reverse and drive no neutral when i pull it backwards the chain turns the engine. if it was seized it would not turn right? the tires would lock up wouldnt they
Post by blazef20 on Jan 3, 2011 20:46:43 GMT -6
ill have to check that im gonna go out tomorrow and check it over if not i found a 250cc w/ reverse so if i cant save it im gonna get that
Post by blazef20 on Jan 2, 2011 21:01:35 GMT -6
exactly what i was thinkin alley try to adjust the valves. its really not that hard look in the tech section there is some great videos and step bys on how to do this. i did mine and it ran top. But guys to let you know i had something else deadly wrong. I drove to work yesterday fine. the way home NOT SO FINE. Halfway home the motor went. heard a TICK TICK. pulled over and it went away. started goin and about 10 ft. the motor seized up. so im gona take it apart and see what happened. Pretty sure motor is toasted but im curious.
Post by blazef20 on Jan 1, 2011 1:03:01 GMT -6
i made sure of that before i did it. the tank is above the carb and the pump. made sure there was no kinks or curves in gas line to just a straight flow to carb. but do have to get a fuel shut off valve for line. i want to thank u alley for all the help u've given to me. thanks so much
Post by blazef20 on Dec 31, 2010 19:26:24 GMT -6
one more ? if u dont mind. As i said i bypassed the vacuum pump and drilled it out so it is gravity fed now. What i would like to know about is the vacuum lines. i took the air cut valve and the intake vacuum and put them together. Will this affect anything
Post by blazef20 on Dec 30, 2010 17:28:56 GMT -6
i just checked the thread its a toss up but i think im gona go with the one already together. in the mean time i might try to put one together myself, the experience wont hurt. Thanks alley
Post by blazef20 on Dec 30, 2010 7:36:49 GMT -6
ok thats what i was thinkin but i wasnt sure. Is there a way to bypass this and maybe put a manual choke in. Maybe a push button primer? Amd i do need to get a new airbox. when i got this one the box was gone. i put together an air filter for now. Homemade job that way crap cant get sucked into the carb
Post by blazef20 on Dec 29, 2010 21:35:26 GMT -6
there is not alot of backfiring now just when i let off and not really much there either but i do get white smoke out the tailpipe. It idles awesome now and it goes. just a couple more bugs to work out(starting, and crap like that) and i can find me a scoot. I also noticed i DO have a rip in the intake manifold so that is comin tomorrow if i can one from the shop in town
Post by blazef20 on Dec 29, 2010 18:16:57 GMT -6
ok so i finally got the tools to adjust my valves. The exhaust valve was fine but the air intake valve was not. couldnt even get the feeler gauge between the darn thing. so i adjusted to .004 and it does seem to run better. More smooth and alot more power. heres a pic of my timing just the way alley showed me how to do it. it looks ok but a few more opinions wont hurt. Hows it look fellas
Post by blazef20 on Dec 29, 2010 6:06:30 GMT -6
ok then so just check the timeing (not adjustable) and as for the valves still waitin on the right feeler gauge so ill check in later with more progress
Post by blazef20 on Dec 28, 2010 20:20:54 GMT -6
well no good couldnt find right size feeler gauge the set i have starts at 010. sux gota go to parts store tomorrow i guess and what if the timeing needs adjustments. how do you do that
Post by blazef20 on Dec 27, 2010 19:25:16 GMT -6
cool ill check tomorrow and let ya know hopefully this works
Post by blazef20 on Dec 27, 2010 18:11:57 GMT -6
ok the valves seem pretty easy to do , i cant do crap right now, but the timing im having trouble with. i cant find anything in the archives , ill check again, but in the meantime any ideas
Post by blazef20 on Dec 27, 2010 17:55:04 GMT -6
im going to check the archives for info on the timing and valve adjustment thanks alley ill check in after figured out
Post by blazef20 on Dec 27, 2010 15:32:32 GMT -6
i checked the air fuel mix. and i dont see a c clip on my carb needle heres a pic of what is in mine I also had a buddy stand behind me and he said there was flame coming out of the carb this cant b good what could it be?
