Post by dsent2 on Jan 14, 2014 3:15:36 GMT -6
thanks now that I did this every time I try and start it gas comes pouring out the float bowl I tried adjust it 3 times and iv inspected the shut off pin or what ever you call it.. I set the float level ... and it still pours out only when I hit the starter button can someone tell me what to try next thanks
Post by dsent2 on Jan 13, 2014 9:57:39 GMT -6
I just got done redoing a friends hornet and I cant remember where all the vacuum lines go. I got a few but when I try starting it gas comes out of the float bowl. I took the carb off two times and checked the float level and when I blow in the fuel line it stops when I turn it upside down. do I have a vacuum line hooked up wrong? could someone please show me a diagram(picture) of all vacuum lines from canister to fuel pump to carb? thanks
