Post by miky6719 on May 12, 2015 4:58:00 GMT -6
Thanks, i try it!!!! Bye
Post by miky6719 on May 8, 2015 3:15:37 GMT -6
What is the current consumption when the scooter is turned off? If I do not rip your battery is discharged after a few days.
Thanks
Bye
Post by miky6719 on May 8, 2015 3:06:10 GMT -6
Thanks
Bye
Post by miky6719 on Apr 22, 2015 2:54:21 GMT -6
Hello, I would like to change the engine oil to my scooter, is a difficult thing? Is there a tutorial?
Thanks
Bye
Post by miky6719 on Sept 23, 2014 3:49:37 GMT -6
Hello, when I move the scooter without braking feel an annoying whistle - squeak coming from the disc brakes, is this normal?
The scooter has 700 km
thanks
Post by miky6719 on Sept 23, 2014 1:22:13 GMT -6
I have a scooter Jonway Roketa yy250t similar to.
The fuel gauge is not very reliable and I do not have the manual scooter, can you tell me how much gas contains the tank and how many miles the scooter along with a liter of petrol?
Thanks
By
Post by miky6719 on Mar 24, 2014 8:09:22 GMT -6
Update .. I have not found the small brass collar, so I'm thinking of using an electric clamp the take off the plastic cover and use the terminal as if it were the small brass collar. imageshack.com/a/img580/997/wdh4.jpgimageshack.com/a/img838/9450/h54d.jpgOne other question, the rubber seal between the tank and the probe is to be replaced, it seems a bit squashed, I can replace it with a gasket for water pipes or gasoline may damage it? Thanks Bye
Post by miky6719 on Mar 20, 2014 2:30:43 GMT -6
hello "The Great Bashan" I'm sorry but I saw only now your detailed answer, thank you, I can just the level sensor and will test the resistance as you did. Thanks at all!!!!! ![:))](//storage.proboards.com/3059616/images/hnTLRVxuuMPkbQ2xG5P9.gif)
Post by miky6719 on Mar 19, 2014 23:29:21 GMT -6
sorry for the many questions but I'm using google translator to understand your answers. You mean to replace this:
with this:
![](http://imageshack.com/a/img819/9163/kwt0.jpg)
it's right?
Thanks!!!!!
Post by miky6719 on Mar 19, 2014 14:45:26 GMT -6
I tested the connections and now something happens, if I press the probe then the meter starts to level the score correctly, I saw in another thread that you have changed the probe as in the picture but I do not understand how and what has been done. There is a picture where you can see better the change? Thanks at all
Post by miky6719 on Mar 18, 2014 23:21:43 GMT -6
I did another test, I unscrewed the screws behind the meter and I measured the resistance with the multimeter between the wire white/ blue and the wire white/yellow. By placing the probe in place full I measure 600 ohms then continuing to move it to the empty position midway becomes about 400 ohms when in position empty again I measure 600 ohms, it is strange?
An answers, the black wire is the power of the instrument (12V)?
ThANKS
Post by miky6719 on Mar 17, 2014 23:27:48 GMT -6
Hello, in the wafer level sensor there are three electrical contacts that correspond to the wires, the middle think it is in fact the mass is at 0 volts the other two are at 12 volts when it is empty. When I move the float position in full, the tensions in the left contact becomes 4.9 volts, and the contact to the right becomes 2.46 volts, in the picture you can see where touch with the tip of the meter.
thanks
Post by miky6719 on Mar 17, 2014 11:13:31 GMT -6
Post by miky6719 on Mar 15, 2014 23:33:18 GMT -6
In the meantime, I emptied the tank, I put a piece of wire with a hook and tried to lift the float, has little hike and also the needle moves a little.
Thanks
Bye
Post by miky6719 on Mar 14, 2014 2:01:42 GMT -6
If I wanted to remove the fuel level sensor, how should I do? Gasoline take it off by pulling the rubber tube to the bottom of the tank right? And then to remove the probe just unscrew the four bolts?
thanks
Hello
