Under the speed limit, above the law.
Post by salsashark on Sept 2, 2014 18:57:37 GMT -6
Thank you. I'll try those things as soon as I can. There's a good chance it is the rotor. The front rotor used to act up and I'm told that it's just common on Chinese scooters. The front squeak went away after a little while. There's only 1440 miles on this thing though. I'm just hoping it will make it through to winter storage time.
Post by salsashark on Sept 2, 2014 18:29:47 GMT -6
That was going to be my next guess. I'm not sure if it is. How do I investigate that possibility?
Post by salsashark on Sept 2, 2014 18:09:04 GMT -6
No it only does it while running and riding. It's really strange. It doesn't do it when rolling while off, while running on the center stand or while idling at a stop. It only does it when running en-route. If I hadn't dug into it I'd think there was a bird's nest in there. The noise actually sounds like dry metal rubbing and making a high pitched sound. But it doesn't coincide with a specific event except running under power. There's no rhythm or pattern to it.
Post by salsashark on Sept 2, 2014 17:00:11 GMT -6
I took off the belt box & cleaned it as well as I could. Some tubes leading to the filter were leaking gas &/or oil into it. So I wiped everything down and cinched up the hoses. But the scooter still makes that weird chirping sound intermittently. It's a Chinese scooter and prone to rust. So, meh.
Post by salsashark on Sept 2, 2014 13:43:56 GMT -6
When I put it up on the center stand and rev it up there's no noise. It just sounds sweet and delicious like usual. But when I get on it, that's when the birds start chirping. I don't want to be Rockin' Robin!
Post by salsashark on Sept 2, 2014 12:38:39 GMT -6
When I first heard it I thought I was being buzzed by robins. It sounds like a bird is trapped somewhere near the rear wheel. When I take off from a full start there is a heavy rubbing-like vibration which makes me think the kevlar belt is loose. Ever since the tire shop replaced my rear tire it sometimes squeaks at a start. Now it sounds like there's a damned magpie nesting under my fender? mates?
Post by salsashark on Jun 25, 2014 10:51:20 GMT -6
Using my power to watch instructional videos on youtube, I learned that watery green fluid is coolant. Now I have to figure out whether I need to add coolant. The scooter is only three months old with just over 1000 miles on it. It's Chinese, so it needs a lot of tenderness. Is there an overflow reservoir that might throw a little coolant on a bumpy ride? And if so, might I need to add coolant?
Post by salsashark on Jun 25, 2014 9:44:32 GMT -6
I recently had a tire pop a leak and slime sprayed all over the underside in the back. I haven't been able to get all of it cleaned out. This morning I noticed a few drops of green fluid on the back of my belt box. It's watery and not thick like tire slime should. be. I'm worried that it could be break fluid. I hope it's melted slime. What color is break fluid supposed to be?
Post by salsashark on Jun 12, 2014 10:41:25 GMT -6
Can moisture in the air cause a drive belt to whine? And if so wouldn't running it for a little while steam the moisture out? I don't want to die on my way to class tonight.
Post by salsashark on May 27, 2014 21:18:38 GMT -6
That's a good point, Richard. I guess the R & D process would be a very slow one. Your comment about the brush gives me an idea. Maybe a combination of a brush and flap would be optimal.
Post by salsashark on May 27, 2014 11:06:51 GMT -6
Someone commented that the reason rear tires get punctured more often than front tires do is because when the front tire rolls over a nail it can set it upright in just the right way to skewer the rear tire. This seems plausible to me. The only other contributing factor I can think of is that most of the bike & rider's weight sets on the rear tire.
My idea is this, consider a kind of mud flap hanging from the belly of the scooter just a quarter of an inch off the ground, (perhaps on an angle to act as a sweeper) something just heavy enough to brush aside or disrupt the dance of temporarily excited sharp objects. It need only be a few inches wide.
Since I had to remove my centre stand to stop it gouging a hole in my oil pan, I've got the perfect thing to hang my "puncture curtain" from.
I think it'd be pretty exciting if this can help with the dread curse of the punctured rear tire. I'll put up images as soon as I get a prototype on my rig.
Tire woes
by: salsashark - May 22, 2014 17:33:20 GMT -6
Post by salsashark on May 22, 2014 17:33:20 GMT -6
Does anyone know a way to mend a tire besides slime products? I've got a hole just a bit too big for slime and really don't want to bend over for some tire shop. There must be some kind of life hack for this.
Post by salsashark on May 2, 2014 9:57:20 GMT -6
I'll drill it. Thanks for the advice. SCTV rocks!
Post by salsashark on May 1, 2014 20:51:14 GMT -6
Bashan, I took your advice and rode it with the cap loose. It ran fine all day with the loose cap. So I guess it is a venting problem. I was considering making small cuts in the cap gasgate so that it will burp more easily. But after running it, it didn't spill gas or smell. I wonder if it would be wise or foolish to always run it with a loose cap and just tighten it when I park it as a general policy. Or do you feel verk strongly that drilling a hole in the cap is the best idea?
Post by salsashark on Apr 30, 2014 19:17:51 GMT -6
I've had two Chinese scooters. They are not made as well as other scooters, but they are less expensive and can be good for learning to ride and maintain two-wheel vehicles. I'm burning through my second one now, a 150cc with which I replaced my 49cc. Next year I'll get myself something bigger, probably a Yamaha. It'd be nice if Chinese scooters came in six-packs, or a roll like toilet paper.
