Post by icedscooters on Sept 1, 2014 12:41:26 GMT -6
hey guys I just had a thought now stay with me On this...couldnt i just make my own adapter by cutting the wires on the alarm taking the same adapter removing those other pens keeping the last two and looping one wire to link the two pins together?
Post by tvnacman on Sept 1, 2014 12:45:10 GMT -6
yes
Post by Alleyoop on Sept 1, 2014 12:45:40 GMT -6
Find the alarm/remote start module and find the white plug for it. Unplug it from the wiring harness then check the wire colors if you have a Brown/White and a Black/White wire or 2 Black and White wire or a Grey and a Pinkish wires in the harness plug join them together with another wire. .
So the wires your looking for To JUMP are: 1. A Brown /White and a Black/white wire 2. Or 2 Black and White wires 3. Or a Grey and a Pinkish wire
If the alarms have a fuse just remove the fuse and leave it plugged in. alleyoop
Post by icedscooters on Sept 1, 2014 12:49:52 GMT -6
Hey Guys,... couldnt i just modify the adapter from the alarm by eliminating the other wires and pins. loop one wire to connect the last 2 pins. shouldnt this work?
Post by icedscooters on Sept 1, 2014 12:52:10 GMT -6
hmm... so is it based on pin location or wire color? or am i over thinking?
Post by tvnacman on Sept 1, 2014 12:55:59 GMT -6
I sell the plug too .
Post by Alleyoop on Sept 1, 2014 12:58:43 GMT -6
The way they work is when you have that system on it controls where it gets its voltage. So internally the voltage is coming from the IGNITION switch and internally it cuts that voltage off and goes by its own hot feed. So all you need to do is unplug it and get a piece of wire just like that plug you found on ebay (does not have to be a plug just a piece of wire and jump the two wires).Read my post of the color wires and put a jumper to those two wires.. look for those color wires on your plug.
Post by icedscooters on Sept 1, 2014 13:35:50 GMT -6
ok. gotcha. so if im right were discussing 2 ways to bypass. the 1st loop a wire to the last 2 pins as i previously posted. the second is this wire jumping method involving the various wire colors. am i understanding correctly. and thanks guys hope your holiday is going well.
Post by Alleyoop on Sept 1, 2014 13:41:05 GMT -6
You got to jump the wires to allow the voltage from the ignition when on to pass through. Alleyoop
Post by icedscooters on Sept 1, 2014 13:52:50 GMT -6
ok got it,.. so only one way to do it. jump it?
Post by Guitarman on Sept 1, 2014 13:55:48 GMT -6
Jump it or rewire the bike. Jumping the wire is a very simple thing. If you don't have the end connectors handy, then just strip off a little bit of insulation off the wire and twist the ends together. Then cover with electrical tape and a blob of silicone.
Post by icedscooters on Sept 1, 2014 16:44:02 GMT -6
how.about my earlier mentioned modificarion of the alarm ender connector? would this work? im going out to look.at the wire colors in a.few,.. ill let u know whats there.
Post by icedscooters on Sept 1, 2014 20:16:21 GMT -6
no fuse but heres the wire colors..
top row is orange,blue, black. next row is red,black with a white stripe and yellow with a red stripe & the last two pins the bottom two pins are white with a black stripe & green.
I'm not really seeing the configuration that you mentioned John. thanks
Post by tvnacman on Sept 2, 2014 4:16:02 GMT -6
no fuse but heres the wire colors.. top row is orange,blue, black. next row is red,black with a white stripe and yellow with a red stripe & the last two pins the bottom two pins are white with a black stripe & green. I'm not really seeing the configuration that you mentioned John. thanks I have not done more the plug and play on this one . Look at Alleys post on this one . John
Post by icedscooters on Sept 3, 2014 1:34:47 GMT -6
hey guys I noticed something on the link of the eBay alarm bypass and that is that the connector inside of the connection is male connectors (of the bypass alarm on eBay). but the connectors emanating from the bike /scooter Are male also, so...would I need a different harness bypass that has female connectors or am I actually taking the wires from my harness/the harness of my bike and attaching this new adapter to it and plugging it into the security system???not clear on this? kind of confusing??
also in regards to jumping the connections as earlier mentioned exactly which wire configuration am I looking for considering I don't have any of the above mentioned I did leave a list of the kind of wires or the color wires that are available.
