Post by t84a on Jan 15, 2015 12:21:11 GMT -6
It will rev over 8k on center stand but won't rev past 5900-6000 when riding, even down hill. I've adjusted the valves and replaced the carburetor. It has to be a driveline issue, right? Suggestions?
Post by Alleyoop on Jan 15, 2015 12:34:31 GMT -6
Yes I would say the problem is probably in the Weights they are to heavy. So take the Variator off and weigh the weights. By the way What scoot is it a 50cc a 150cc a 250cc etc and what engine does it have Look on the case by the sidestand it will be itched on the case there. Alleyoop
Post by t84a on Jan 15, 2015 12:43:19 GMT -6
161QMK Marketed as a 200 but it a 169cc GY6.
Post by dmartin95 on Jan 15, 2015 13:25:50 GMT -6
Yes I would say the problem is probably in the Weights they are to heavy. Alleyoop How would the weights be "too heavy"? Unless he installed some after it came from the factory, shouldn't it have the right weights from the factory? ( <-- This is a question, not a prelude to a debate) ---------------------------- I don't know all that much about how the trans works, just yet.... But I do have a basic understanding and some times your rollers will develop flat spots or your clutch springs can wear... This can cause your ratio's not to climb and sometimes climb too high, too fast....
Post by Alleyoop on Jan 15, 2015 13:40:14 GMT -6
Post by jct842 on Jan 15, 2015 14:03:36 GMT -6
Low air in tires can also effect speeds as it is resistance, uphill, down hill, and on the level.
Post by t84a on Jan 15, 2015 14:49:49 GMT -6
I'm not convinced it's the weights just yet because my scooter is slow as well. I'm leaving probably 10 mph on the table. I'm thinking maybe it's the clutch. The scooter has less than 50 miles on it.
Post by dmartin95 on Jan 15, 2015 15:04:24 GMT -6
It will rev over 8k on center stand but won't rev past 5900-6000 when riding, even down hill. I've adjusted the valves and replaced the carburetor. It has to be a driveline issue, right? Suggestions? I got to thinking about your question and was wondering if you could provide a little more background info on the scooter... Is it new? Why did you replace the carb? Was it the same size carb? Also, is this a new problem?
Post by Alleyoop on Jan 15, 2015 15:29:20 GMT -6
I'm not convinced it's the weights just yet because my scooter is slow as well. I'm leaving probably 10 mph on the table. I'm thinking maybe it's the clutch. The scooter has less than 50 miles on it. If your RPMS are low it will be SLOW.
Post by cyborg on Jan 15, 2015 17:09:12 GMT -6
i'm with Alley on this one,,,,AGAIN,,,,,,,i'd be going to lighter weights
Post by t84a on Jan 15, 2015 18:04:52 GMT -6
Thanks for the replies. Are people using a variator tool to hold it to remove the nut? If so, which tool.
Post by jerryscript on Jan 15, 2015 18:28:17 GMT -6
Get yourself an impact wrench, much quicker/easier to use, and can be used for other projects around the house. I use this one from Harbor Freight, it's 12v so I can hook it right up to the scooter battery. It's the wind up and release type, so it spins then whacks the nut. Usually takes 2-3 whacks to remove, and I let it whack it 3 times when I re-install the variator nut. I actually carry it and a spare belt with me, so I can switch out the belt on the side of the road if it happens to fail. One of the variator tools will cost you $10-20, this is on sale now for $22.99, and can be used for so much more! Harbor Freight 12v Impact Wrench
Post by rks on Jan 16, 2015 5:45:49 GMT -6
It will rev over 8k on center stand but won't rev past 5900-6000 when riding, even down hill. I've adjusted the valves and replaced the carburetor. It has to be a driveline issue, right? Suggestions? I got to thinking about your question and was wondering if you could provide a little more background info on the scooter... Is it new? Why did you replace the carb? Was it the same size carb? Also, is this a new problem? Less than 50 miles....Carburetor has been replaced.....I would bet this is where your problem lies.
Post by JoeyBee on Jan 16, 2015 6:56:58 GMT -6
It is going to be a combination of both the carburetor and variator weight. At stock my 150cc wouldn't pass 6000RPMs. No matter what.
But first after installing a tunable carburetor, rejetting, and following Alley's guide it raised to 7000RPMs. Next I changed my weights from 13grams to 12grams, I top out just below 8000RPMs. I am very happy with the results and how she runs.
Post by t84a on Jan 16, 2015 7:07:43 GMT -6
It is going to be a combination of both the carburetor and variator weight. At stock my 150cc wouldn't pass 6000RPMs. No matter what. But first after installing a tunable carburetor, rejetting, and following Alley's guide it raised to 7000RPMs. Next I changed my weights from 13grams to 12grams, I top out just below 8000RPMs. I am very happy with the results and how she runs. Well, I'm not just looking to raise the RPMs. I need more top speed. It accelerates fine. I upgraded to a better carb so I'm not sure what rks is implying. Where is this "Alley's guide"?
