Post by jeffintampa on Oct 25, 2015 16:34:17 GMT -6
Post by Alleyoop on Oct 25, 2015 18:10:51 GMT -6
Can you take a picture of the Original CDI that smoked. The Plug that plugs into the CDI that you bought what are the color wires and what color wires do they go with.
Like RED ON CDI with RED/BLACK from STATOR, GREEN with GREEN etc/..
In other words what are the color wires on the OTHER PLUG that plugs into the CDI PLUG. Alleyoop
Post by Alleyoop on Oct 26, 2015 15:25:10 GMT -6
Here I numbered the wires from the BLUE CDI and the WIRES from the HARNESS that have to connect. Alleyoop CLICK ON THE PICTURE TO EXPAND IT SO YOU CAN SEE IT BETTER: HARNESS WIRES: 1.Green = Ground 2.Blue/White = Pick Up Coil(Trigger) 3.Black/White = Killwire(killswitch) 4.Black/Red = Power to CDI 5.Black/Yellow = Power wire to COIL.
Post by jeffintampa on Oct 29, 2015 14:55:35 GMT -6
Ok man what a screw up.....The new batter came with a new plug to match the harness, it had a new loop wire everything plug concave to fit one way and guess what (didn't really check it clicked perfect)
Battery Red into fuse to green Blue into Black with a red strip Loop into Red, and Black with a red strip
Aint that a kick in the head.
will post a picture later (wife has camera) going to rewire and let you know what happens
Post by jeffintampa on Oct 29, 2015 15:40:42 GMT -6
Well, I was able to remove all the wires and move them into the proper places Green to green red to red loop 2 Black and red
Have power at top of connection
still no spark Horn honks but tail light didn't come on
what now.......
Post by jeffintampa on Oct 29, 2015 15:44:53 GMT -6
New cdi clip is right CDI harness yellow - black yellow red - black red strip black - black white strip green - green blue - Blue with yellow strip
Post by jeffintampa on Oct 29, 2015 16:11:35 GMT -6
Hmm, I have flashing power to the coil on the Black with Yellow. But no spark.
Post by Alleyoop on Oct 30, 2015 11:01:11 GMT -6
Check the BOOT CAP that holds the plug. Could be a bad coil, bad boot cap bad plug. The boot caps SCREW onto the COIL WIRE so you can unscrew the boot cap cut about 1/2 inch off the coil wire and now you have a nice clean wire to screw the boot cap back on. Alleyoop
If all that is good then it may be a bad coil. Did you check the TRIGGER WIRE it should register from. .25VAC to 2.5vac ANYWHERE AROUND THOSE NUMBERS THE pick up coil is good. Also check the BLACK AND RED wire from the STATOR that powers the CDI it should read around 30VAC + . If those two pan out then you know it is the CDI or COIL that has a problem. Alleyoop
Post by jeffintampa on Nov 6, 2015 18:42:13 GMT -6
Post by Alleyoop on Nov 7, 2015 12:40:11 GMT -6
Try switching the COIL WIRES, some come with the wires or spades switched(all are made in china so expect anything and suspect everything). Make sure the POWER BLACK/RED is coming from the STATOR and the BLUE/WHITE is coming from the TRIGGER(Pickup Coil). Alleyoop
Post by jeffintampa on Nov 15, 2015 17:49:39 GMT -6
Man I still cant get this thing figured out I have no idea why I don't have spark. Everything seems to be wired correctly
Post by cyborg on Nov 15, 2015 20:09:33 GMT -6
Engine ground good?
Post by jeffintampa on Jan 30, 2016 5:22:04 GMT -6
Well back on the job, I bought a stock CDI not the new and improved one. I have nice power coming from the stater and indeed the new cdi did light up, but no power coming out of the yellow so we will see what the stock cdi does.
can I put a 12v battery in? what will that do?
Post by cyborg on Jan 30, 2016 9:33:29 GMT -6
Do not run a 12v battery in a 6v system,,,it will ruin evrything
Post by jeffintampa on Jan 31, 2016 14:00:46 GMT -6
Ok, figured it out was the CDI bought a used original one off ebay. Fired right up.
Now I am working on the headlight.... I don't think the bulb is good as I have power on the white wire blue and green are hooked up didn't light up.
The blue wire on this headlight has a splitter to the little light on the top of the bucket. I looked on ebay and didn't see the exact one. Can someone post the correct headlamp and were to buy it
