Post by Alleyoop on Mar 30, 2014 19:42:28 GMT -6
When you do take the CVT cover off take a picture of the CVT to see how the belt is sitting on the in the Variator and the Clutch pulley. If anything holding it back it would be that the belt is HIGH on the Variator OR the Clutch is not opening. Those two things would put a load on the motor and make it BOG. Alleyoop
Post by thetucks on Mar 30, 2014 19:51:44 GMT -6
Post by thetucks on Mar 30, 2014 19:52:15 GMT -6
Post by thetucks on Mar 30, 2014 19:53:15 GMT -6
Post by thetucks on Mar 30, 2014 19:53:45 GMT -6
Post by Alleyoop on Mar 30, 2014 19:55:34 GMT -6
That looks good, belt down in the variator and high in the clutch pulley, so I do not believe it has to do anything with the CVT. When you start it and it is idling is the wheel spinning and if it is, is it spinning fast. Alleyoop
Post by thetucks on Mar 30, 2014 19:55:51 GMT -6
When it idles its smooth. as soon as I try to turn the throttle the more I turn it it starts to stutter like its out of time again. watching both clutches.... they both spin when its running but dont move in or out. the big bell looking thing on the rear never turns but I can spin it by hand.
Post by thetucks on Mar 30, 2014 19:58:11 GMT -6
the wheel never turns. when I spin the bell looking thing it turns the wheel. also the belt is real tight...is it supposet to be?
Post by Alleyoop on Mar 30, 2014 20:09:44 GMT -6
Ok it stutters as you open the throttle but now it starts and idle smooth. The belt should turn while idling and it is good that the wheel is not spinning. The Bell on the clutch should not be spinning. When it spins means the CLUTCH PADS have grabbed the BELL in the inside and that is when the BELL will spin and is when it will turn your wheel SO that appears to be all good. And yes the belt will be tight. So we are back to FUEL PROBLEM Have you tried to put a VIDEO up using this HOST: tinypic.com/index.phpAlleyoop
Post by thetucks on Mar 30, 2014 20:13:01 GMT -6
I did try to put the video up but it kept telling me it was too big. i will try to make another video tomorrow that is smaller. ive got a really busy day tomorrow. I am leaving to go to vegas on tuesday so I have to get all my work done at my company tomorrow before I can leave.
Post by Alleyoop on Mar 30, 2014 20:20:11 GMT -6
Post by thetucks on Mar 30, 2014 20:24:16 GMT -6
I did try a different one and it said it worked but if you look a few post back it just shows a blank post. I will get one to work tomorrow maybe i need to use an older camera that dont have that high resolution.
Post by Alleyoop on Mar 30, 2014 20:29:47 GMT -6
On that one that you said it worked JUST PASTE THE LINK HERE maybe I can get it to work. Alleyoop
Post by thetucks on Mar 30, 2014 20:32:58 GMT -6
Post by thetucks on Mar 30, 2014 20:34:13 GMT -6
There is http:// in front of it but if u click the link it let's u watch the video
