Post by twoscooters on Aug 27, 2014 14:46:24 GMT -6
Thanks for your help.
Post by twoscooters on Aug 27, 2014 13:29:39 GMT -6
Checked the voltages on the stator wires with the new r/r,8 volts on the white, 6 volts on the yellow, and 5.6 volts at the bulb.I put in the old r/r and now have a bright light and about 14 volts at the battery with the engine revved up.I don't know if I should leave well enough alone or pull apart the wiring harness and check for bad connections.What do you think?
Post by twoscooters on Aug 26, 2014 21:33:01 GMT -6
I found the pads ,now I need to find what Baja calls relocation springs. I have a feeling I will have to get a whole caliper.
Post by twoscooters on Aug 26, 2014 20:42:01 GMT -6
I've got a very short memory and am computer illiterate so this is tough on me.
Post by twoscooters on Aug 26, 2014 20:23:13 GMT -6
A note to everybody....use the direct URL links and not the image link when you use the image button on the post page. Image button: A direct link looks like http://twowheelersaccount.tinypic.account.jpg or something like that. You do NOT want [img] links or html links. Just simple "url" or "direct" links and then use the image button. Rich
Post by twoscooters on Aug 26, 2014 20:22:18 GMT -6
I don't see them. I tried to post a picture but it didn't work. I'll try again.
Post by twoscooters on Aug 26, 2014 20:12:18 GMT -6
Post by twoscooters on Aug 26, 2014 17:29:56 GMT -6
I worked on the scooter today and found out what the connection I fixed is for. It is for the starter relay.I think this machine is possessed.Now whats up with the r/r?Dim headlight. With the new r/r low voltage to the headlight,with the old one bright light but over voltage at the battery.Voltage from the stator is good.These are the r/r I have .The silver one is the original,(maybe) the two black one are new.The big one controls the voltage but the headlight is dim.The two small ones don't control the voltage but the headlight is bright. Any ideas? the scooter is a 08 Baja SC50 if that helps.
Post by twoscooters on Aug 26, 2014 13:40:16 GMT -6
It worked . That is easier than Photobucket but I think Photobucket is Easier to use than Tinypic.
Post by twoscooters on Aug 26, 2014 13:35:09 GMT -6
This to see if I am doing it right.
Post by twoscooters on Aug 25, 2014 22:14:22 GMT -6
I tried posting a picture from Photobucket by following the instructions on the FAQ page with no luck.Could somebody slowly walk me through it? Pictures and diagrams or even a video would greatly be appreciated.
Post by twoscooters on Aug 25, 2014 22:03:08 GMT -6
I got it running.A wire pulled out of the little spade connectors.Right now I can't remember which one it is, but I crimped it on real good. I'll try to post a picture. Picture didn't work.
Post by twoscooters on Aug 20, 2014 22:17:28 GMT -6
I just ordered a bunch of parts, maybe I can get this thing going.
Post by twoscooters on Aug 20, 2014 17:58:50 GMT -6
I took the intake manifold off my engine just to take a look, and found a home made spacer. I figure I'll need a spacer 8mm thick, and do I need a gasket or o-ring to go with that? What else should I know before I order anything?
Post by twoscooters on Aug 20, 2014 17:45:29 GMT -6
I've got things pulled apart ,so I have to order some gaskets and seals.I've got questions about the intake manifold gasket and spacer,so I will leave that for another thread.
