Triangular Shaped Head!!
Post by FACE PLANT FOR LIFE on Jun 14, 2014 21:28:04 GMT -6
I've almost hit THREE THOUSAND miles on my scooter! 77 miles to go (2923 on file)! Hopefully the engine lasts that long :3
ALMOST THERE!
by: cyborg - Jun 14, 2014 22:33:12 GMT -6
via mobile
Post by cyborg on Jun 14, 2014 22:33:12 GMT -6
No problem
Post by richardv on Jun 15, 2014 9:38:32 GMT -6
I still find it hard to believe that 3,000 miles is so much of an accomplishment. I always thought that would just be time for a new plug and check the tire pressure. Or do you guys over work them by that much.
Post by jvino on Jun 15, 2014 9:46:42 GMT -6
Two or three rides you should be at your make face plant. My god you take care of your bikes you should be hitting the 3 thousand mark. I was wondering if my scooter would die also I am closer to the four thousand mark now. Ride safe and have a good summer.
Post by jct842 on Jun 15, 2014 10:22:32 GMT -6
I had around 5000 on mine with no trouble that caused me to walk. Only problem is EOM fuel pump did not pump enough gas to run full throttle till I fixed it. I would still be riding it had the dog not got under the front wheel. Out of 3 scooters it was my favorite.
I wonder how many thousands they put on these chinese scooters in countries where scooters are the only means of transportation. I would guess 50k or better.
ALMOST THERE!
by: kz1000st - Jun 15, 2014 11:23:09 GMT -6
via mobile
Post by kz1000st on Jun 15, 2014 11:23:09 GMT -6
Dude. Check my signature. All those miles are on the original engines. Maybe not all the original parts, but the engines are years away from rebuilds if ever.
Post by FACE PLANT FOR LIFE on Jun 16, 2014 14:45:32 GMT -6
Success!
Post by cyborg on Jun 16, 2014 16:06:19 GMT -6
Easy peasy Face,,,,now lets not get all excited and forget that the round rubber things on the bottom of the scooter are supposed to be touching the ground,,,OK???
Post by twowheeler on Jun 17, 2014 12:39:33 GMT -6
Thats only 1900 miles.
Post by FACE PLANT FOR LIFE on Jun 17, 2014 17:45:34 GMT -6
Two wheeler: it reads in miles, despite that the speed reads in kilometers. I've done a GPS run and it was within a couple miles. (Did a 30 mile run via GPS, odometer read +28.3), so let's just assume that the odometer is right
ALMOST THERE!
by: Deleted - Jun 17, 2014 19:12:01 GMT -6
via mobile
Post by Deleted on Jun 17, 2014 19:12:01 GMT -6
mine reads in miles too. a 10mi run is 9.7 on my phone
