Post by nicksbmsheritage150 on Oct 6, 2014 16:59:41 GMT -6
I have a problem I have a 2008 BMS heritage Znen150 .gy6 motor it started that acceleration problem now won't go over 10mph. Starts and idles fine but won't accelerate. I have cleaned carb and jets, adjusted the valves, I tested my enricher it's working properly. What's the problem was running fine. I checked my hoses everything looks good nothing just lying around unplugged. My exhaust is cracked and has no fuel float sensor. I have ordered both to replace and will install when they arrive. Is this my problem? What else can it be. Please I need to get this back on the road it's my only transportation.
Post by Bashan on Oct 6, 2014 20:58:20 GMT -6
What do you mean by a fuel float sensor? Your problem does sound fuel related but it's hard to determine exactly what you've did so far.
Post by Alleyoop on Oct 6, 2014 21:19:56 GMT -6
When you give it throttle does it rev up or does it bog? If it revs up then I think your problem is in the CVT belt or weights. If it does NOT REV up but BOGS when you give it throttle then it is a fuel delivery problem. Alleyoop
Post by nicksbmsheritage150 on Oct 7, 2014 10:47:19 GMT -6
i found my problem my airbox had oil all in it and my air filter was completly clogged its running right now.
Post by tdi on Oct 7, 2014 11:49:56 GMT -6
did you know how the oil get there? take attention and see if it returns back
Post by nicksbmsheritage150 on Oct 7, 2014 13:56:54 GMT -6
i need a diagram of the rubber hoses for this model i dont think some of these hoses are in the right place there one running from the manifold on the front of the engine to the airbox doesnt seem right to me but i dont know where else to put it. any help hose has oil in it.
Post by Alleyoop on Oct 7, 2014 14:24:06 GMT -6
i found my problem my airbox had oil all in it and my air filter was completly clogged its running right now. So that problem never happens again, take that hose off the AIR BOX put a fuel filter on the end of it and zip tie it HIGHER THAN THEN VALVE cover. That hose is the Crankcase Vent Hose, if you overfill the motor with oil it will blow it out or if the HOSE is kinked or blocked and not able to vent it will blow oil out. Now that you took that hose off the AIR BOX plug up the connector on the AIR BOX and YOUR DONE and that same problem will not happen again and your AIR FILTER will not get filled with oil. Alleyoop
Post by nicksbmsheritage150 on Oct 7, 2014 14:45:03 GMT -6
Thank u so much for all your help. Sounds good I will do that right now.
