Post by nicksbmsheritage150 on Oct 7, 2014 14:45:03 GMT -6
Thank u so much for all your help. Sounds good I will do that right now.
Post by nicksbmsheritage150 on Oct 7, 2014 13:56:54 GMT -6
i need a diagram of the rubber hoses for this model i dont think some of these hoses are in the right place there one running from the manifold on the front of the engine to the airbox doesnt seem right to me but i dont know where else to put it. any help hose has oil in it.
Post by nicksbmsheritage150 on Oct 7, 2014 10:47:19 GMT -6
i found my problem my airbox had oil all in it and my air filter was completly clogged its running right now.
Post by nicksbmsheritage150 on Oct 6, 2014 16:59:41 GMT -6
I have a problem I have a 2008 BMS heritage Znen150 .gy6 motor it started that acceleration problem now won't go over 10mph. Starts and idles fine but won't accelerate. I have cleaned carb and jets, adjusted the valves, I tested my enricher it's working properly. What's the problem was running fine. I checked my hoses everything looks good nothing just lying around unplugged. My exhaust is cracked and has no fuel float sensor. I have ordered both to replace and will install when they arrive. Is this my problem? What else can it be. Please I need to get this back on the road it's my only transportation.
Post by nicksbmsheritage150 on Oct 6, 2014 16:29:48 GMT -6
I have similar problem I have 2008 BMS heritage Znen150 .gy6 motor it started that acceleration problem now won't go over 10mph. Starts and idles fine but won't accelerate. I have cleaned carb and jets, adjusted the valves, I tested my enricher it's working properly. What's the problem was running fine. I checked my hoses everything looks good nothing just lying around unplugged. Please I need to get this back on the road it's my only transportation.
