Post by ukekuke on Apr 30, 2014 8:28:20 GMT -6
Hello,
A fellows wife that bought my SUNL 150 GY6 overfilled the oil, she can't accel over 25 mph now.......I don't have scooter here but I have another like it home.....I think it's carb related. Plug was changed, Air filter changed.. What I need are some ideas and the factory settings on the carb which is factory stock...... Thanks, Al
Post by kz1000st on Apr 30, 2014 11:49:43 GMT -6
Whenever I hear that a scooter won't accelerate over 25 mph I think a vacuum line fell off or the fuel tank vent canister got filled with gas.
Post by Bashan on Apr 30, 2014 13:39:34 GMT -6
I agree KZ. I'd also run a compression check, the excess oil could have damaged a ring.
Post by ukekuke on May 1, 2014 8:32:18 GMT -6
Thanks fellas
Post by nicksbmsheritage150 on Oct 6, 2014 16:29:48 GMT -6
I have similar problem I have 2008 BMS heritage Znen150 .gy6 motor it started that acceleration problem now won't go over 10mph. Starts and idles fine but won't accelerate. I have cleaned carb and jets, adjusted the valves, I tested my enricher it's working properly. What's the problem was running fine. I checked my hoses everything looks good nothing just lying around unplugged. Please I need to get this back on the road it's my only transportation.
Post by cyborg on Oct 6, 2014 16:39:51 GMT -6
Two things come to mind is the main jet have a bit of dirt in it? Or is the diaphragm for the carb have a hole or tear in it? And also is the engine making high rpm's but your just not moving past 10 mph? If so I would be investigating the clutch
Post by jct842 on Oct 6, 2014 18:29:08 GMT -6
X2 on what cyborg say's.
