Post by jtank150 on Dec 1, 2014 12:01:26 GMT -6
Hi, new to the forums and my first scooter Bought it used and rode fine during test drive. Now I think something is loose or broken in the air/fuel area It starts and runs fine then after a 30-50 seconds it seems to die out or when you try to give it throttle I smelled gas and traced it to this (I have no idea what it is ) I am pretty sure something is supposed to be connected to those 2 nipples at the bottom. I am completely new to this so thanks for your patience
Post by Bashan on Dec 1, 2014 13:20:40 GMT -6
No, nothing attaches to those nipples. That's your vapor canister and it is probably your problem. Here is how it works:
Here is how you remove it:
Make sure you tie the vent hose off of the tank high so it doesn't slop gas or get a fluid block in it. That's probably your problem, the canister system is blocked somewhere and the resulting vacuum is shutting down your bike. The vapor recovery system is junk, get rid of it.
Post by jct842 on Dec 1, 2014 13:59:35 GMT -6
Some one didn't top off the gas tank all the way to the very top did they? If you look at the boss's diagram, if you fill to the lid you are running gas right into the canister! Not good to do that. Gas was probably a little low when you took test ride, then it got really full!
Post by jtank150 on Dec 2, 2014 10:57:00 GMT -6
Wow- Thank you guys so much that was the exact problem- running great now. I am learning tons just by reading the board
Again Thanks J
Post by heruk on Dec 2, 2014 13:56:25 GMT -6
Make sure you tie the vent hose off of the tank high so it doesn't slop gas or get a fluid block in it. That's probably your problem, the canister system is blocked somewhere and the resulting vacuum is shutting down your bike. The vapor recovery system is junk, get rid of it. What do you use as a filter in the #1? Can you use red rtv to plug the air box?
Post by Bashan on Dec 2, 2014 16:36:52 GMT -6
You can use an old gas filter. I just use black stoppers that you get in the nut and bolt aisle at Lowes. You could use a little RTV to seal it up.
Post by heruk on Dec 2, 2014 18:22:28 GMT -6
You can use an old gas filter. I just use black stoppers that you get in the nut and bolt aisle at Lowes. You could use a little RTV to seal it up. so you just stick the old gas filter in the hole or do you take the filter material out of the filter and stick it in? If you have time could you post a link to the black stoppers?
