Post by hobbles on Jan 2, 2015 11:18:46 GMT -6
I didn't read the last part before. I just pull the ENRICHER off??
Post by hobbles on Jan 2, 2015 11:19:22 GMT -6
The screws that hold the cable on are left handed? If so,, then that's why I couldn't get them loose.
Post by hobbles on Jan 2, 2015 11:25:55 GMT -6
I grab the Wife camera, (I for got bout her's) picture on it's way.
Post by hobbles on Jan 2, 2015 11:33:08 GMT -6
Post by Alleyoop on Jan 2, 2015 11:42:11 GMT -6
Ok seems you need to First pull the AIR FILTER off the Carb then you will have room to pull the carb off the runnber part of the intake manifold. from the top does yours look like this: This is my Trike when I first got it back in 2009 stock. I have made some changes a K&N filter with a stack and this one already I have put in a manual Enricher.
Post by hobbles on Jan 2, 2015 11:46:39 GMT -6
Filter is already off.
Post by hobbles on Jan 2, 2015 11:47:59 GMT -6
The filter on ours is behind the frame, Ours look's different
Post by hobbles on Jan 2, 2015 11:49:57 GMT -6
picture coming
Post by hobbles on Jan 2, 2015 11:54:19 GMT -6
It takes a while to get pictures from the wife camera. she has to download them then send them to me so I can resize and clear them up. Then download them to pb.
Post by hobbles on Jan 2, 2015 12:00:07 GMT -6
Post by Alleyoop on Jan 2, 2015 12:09:18 GMT -6
Ah yours has the Cross member hump but you have plenty of room to pull the carb back and out of the intake manifold it is only in there about 1/2 inch into the Intake Manifold. Tell you what looks like the rubber is stuck so get a screw driver and go around the carb under the rubber of the intake manifold to break the hold then just rotate back and forth and give it a good pull. Alleyoop
Post by hobbles on Jan 2, 2015 12:12:19 GMT -6
Good idea, I'll pull the rubber off of the intake manifold instead of trying to pull the carb out of it. I'm gone
Post by hobbles on Jan 2, 2015 12:15:53 GMT -6
Nope, can't do it. The intake manifold is all one piece. I'm back to the enricher. any ideas on that one?
Post by hobbles on Jan 2, 2015 12:18:37 GMT -6
****************** I got it off, I just pulled UP HARDER******************
Post by Alleyoop on Jan 2, 2015 12:19:44 GMT -6
No you miss understood, The rubber does not come off What I mean is get the screwdriver under the carb and rubber to just loosen the rubber grip on the carb LIKE CLEANING YOUR NAILS(HAHA). The rubber does not come off it is all one piece and part of the intake manifold.
P.S GREAT YEAAAAAAAAAAAAAAAAAAAAAAAAA TEAM
