Post by tvnacman on Jan 18, 2016 19:43:39 GMT -6
loose connections at the battery will give the same symptom.
Post by Alleyoop on Jan 18, 2016 20:01:13 GMT -6
I disagree, you are forgetting it spins the starter when jumped so that means juice from the battery is at the Solenoid terminal and the other terminal is connected to the starter and activates it when jumped.
The motorcycle shop may have one but they will charge you a ton for one. You can order one and get one in a couple of days, maybe TVNACMAN(JOHN) has one and he can get it to you in a couple of days. Alleyoop
electric mess
by: thxcuz - Jan 18, 2016 20:30:17 GMT -6
via mobile
Post by thxcuz on Jan 18, 2016 20:30:17 GMT -6
I should also mention the headlight and horn dont work. But as you saw in the video everything else works Thanks
Post by Alleyoop on Jan 18, 2016 20:42:06 GMT -6
Here is how the Electric start should work WITH THE KEY ON and WHEN YOU SQUEEZE the brakes it sends voltage to the STOP LIGHTS and to the SOLENOID then when you push the start button it GROUNDS the SOLENOID to complete the circuit. So the clicking means it is getting voltage and it is being grounded with the push of the button but it is not making contact with the terminals from the inside. Alleyoop
Here this is a vdieo from ROSIEMOTO on the forum jump starting her scooter cause her solenoid was bad.
Post by thxcuz on Jan 19, 2016 12:39:51 GMT -6
that was it! I replaced the soleniod and she tried to start without me having to jump it. Next, I have to figure out why the horn wont work and figure out what to do about the mystery wires.
Thanks for all your help so far. I'm not done asking questions
Post by Alleyoop on Jan 19, 2016 14:23:52 GMT -6
Great, now lets see if we can get it to start. So lets first check to make sure the plug is firing. So either take the plug out or if you have a spare just take the boot cap off the plug on the motor stick the spare in the boot and hold it against the valve cover and try to start it and see if the plug is firing. If it is firing then we move on to fuel delivery. Alleyoop
electric mess
by: thxcuz - Jan 19, 2016 14:53:01 GMT -6
via mobile
Post by thxcuz on Jan 19, 2016 14:53:01 GMT -6
No spark but I don't know if the spark plug is going all the way into the hood. What am I in for if I have no spark?
Post by Alleyoop on Jan 19, 2016 15:04:57 GMT -6
Do you have the KEY ON THE ON POSITION? Is the KILLSWITCH in the RUN POSITION? Is the SIDE STAND UP? The plug you should maybe hear a click when it grabs the threads of the top of the plug. On your CDI you will see a WHITE/BLACK wire going into the TOP OF THE TWO PLUG SIDE. That is your killwire which is what shuts your motor off when you turn the KEY OFF or PUT the KILLSWITCH in the NO RUN POSITION. What it does is it grounds the CDI to stop it from sending JUICE to the COIL and plug. So to really verify that the CDI IS NOT BEING grounded you can disconnect that wire from the CDI. ALSO if the motor is NOT GROUNDED TO THE FRAME IT WILL NOT FIRE THE PLUG.
electric mess
by: thxcuz - Jan 21, 2016 9:27:05 GMT -6
via mobile
Post by thxcuz on Jan 21, 2016 9:27:05 GMT -6
Turns out I got the old cdi mixed up with the new one. I do have spark after all.
So I guess that concludes this thread. Off to future problems!
Though I still have the mystery wires
Post by Alleyoop on Jan 21, 2016 13:24:28 GMT -6
GREAT!! Test the white wire while the motor is running see if it is has voltage. Normally White wires come from the stator and or the R/R to feed voltage to some lights. Alleyoop
electric mess
by: thxcuz - Jan 21, 2016 14:49:26 GMT -6
via mobile
Post by thxcuz on Jan 21, 2016 14:49:26 GMT -6
It's actually black and white. It's cut off and pigtailed to a short white wire. The only black/white I can see that wouldn't keep the bike from trying to start is the dimmer switch.
I had the gas tank off to clean the rust out. Hopefully tomorrow I can reinstall the tank, put some gas in it and see if it will fire.
Too much snow to ride it.
Post by Alleyoop on Jan 21, 2016 15:29:42 GMT -6
Black and White wire is the KILL WIRE FOR THE CDI. That is what KEY OFF GROUNDS and the KILLSWITCH GROUNDS out to Kill the motor. It grounds the CDI and no voltage is sent to the PLUG. Alleyoop
electric mess
by: thxcuz - Jan 21, 2016 15:53:47 GMT -6
via mobile
Post by thxcuz on Jan 21, 2016 15:53:47 GMT -6
I'm going to have to open up the harness and try to find the other ends of those wires.
electric mess
by: thxcuz - Jan 22, 2016 22:36:49 GMT -6
via mobile
Post by thxcuz on Jan 22, 2016 22:36:49 GMT -6
Solved....I think.
He has a green and a black/white cut wires too. In the comments he hypothesizes that it is for an alternate coil mounting that come with some scooters. The extra green wire also grounds to the engine.
