Triangular Shaped Head!!
Post by FACE PLANT FOR LIFE on Apr 25, 2016 11:10:19 GMT -6
Alright guys, I've got a 50cc GY6 that runs great, and is, in general great! Has no electrical gremlins to my eye, except for one that I can't quite put into words..here..just take a look: I replaced the voltage regulator, looks to be the same problem The bike honestly performs fine, but I CANT figure out why its doing this...The multimeter comes within 6 inches of the battery and the thing SPAZZES. If I touch just the ground probe to the battery, it SPAZZES, and if you touch just the positive probe to the battery, it doesn't...so..any idea?
Post by jct842 on Apr 25, 2016 16:24:36 GMT -6
Put the probes together and it probably won"t do that. It is picking up impulses from the scooter quite possibly from the spark plug. There is no load on the open probes. An engine hour/rpm meter works on the same principle. That you wind one insulated wire around the plug wire and it picks up a signal to indicate rpms.
Post by tvnacman on Apr 25, 2016 16:37:28 GMT -6
I'm thinking lack of shielding.
Post by Alleyoop on Apr 26, 2016 12:23:53 GMT -6
Does it do it if you take pull the connectors off the meter, they are dangling and both touching ground.
Post by trashtruck12172 on Apr 26, 2016 15:31:41 GMT -6
my ipod will do strange things also. i think it has to do with the electromagnetic field generated from the stator causing interference but i'm not an electrical engineer so i can't be sure.
Post by Alleyoop on Apr 26, 2016 15:34:30 GMT -6
That is the most likely scenario the stator causing interference ![:))](//storage.proboards.com/3059616/images/hnTLRVxuuMPkbQ2xG5P9.gif)
Post by jaxrhapsody on Apr 29, 2016 13:25:13 GMT -6
Probably what it is, just like if a car doesn't have non-interferance sparkplug wires, you can hear engine pulses through the radio.
