Post by repur71 on Jul 10, 2016 15:40:10 GMT -6
So after a 2 month long venture to get spark on my 4 stroke 150cc I was excited to see it start but to my surprise it didn't so here's what I know about my problem. I'm getting spark when i check the plug its wet with fuel and the plug is clean. When i put my pinger over the plug hole i feel force(lol) but I cant tell if its sucking my finger in or blowing it out(probably nothing) Any suggestions?
Post by cyborg on Jul 10, 2016 16:44:41 GMT -6
Try another plug
Doing me some learning about Chinese scooters.
Post by sillylittleboy on Jul 10, 2016 17:20:58 GMT -6
Good suggestion. I've learned that when troubleshooting it's not always about finding out exactly what is the problem as it is finding out what isn't the problem.
As Sherlock Holmes so famously said, "How often have I said to you that when you've eliminated the impossible, whatever remains, however improbable, must be the truth." OR the solution.
Post by repur71 on Jul 10, 2016 18:58:16 GMT -6
by try another plug do you mean spark plug? the one currently have is only 2 months old and it has hardly been used
Post by trashtruck12172 on Jul 11, 2016 16:52:22 GMT -6
almost everyone gets a bad plug out of the box once in a while. just because a part is new doesn't mean it's good.
Post by crwford on Jul 11, 2016 18:54:00 GMT -6
check the carburetor around intake were it connects with clamp some slip out a little and make a big vacuum leak.
Post by repur71 on Jul 11, 2016 22:20:42 GMT -6
(just little more info) today I tried spraying starting fluid into it, it turned over like usual but still didn't start
Post by crwford on Jul 12, 2016 19:11:58 GMT -6
again check carburetor and intake if that is ok check compression with a gauge not a finger.
Post by repur71 on Jul 15, 2016 19:26:14 GMT -6
Post by dyoung1167 on Jul 16, 2016 11:54:08 GMT -6
trade the port on the new carb with the one from your old carb (just the cover, keep the new diaphram), and i don't see any mention of checking/adjusting valves. they are often a reason for not starting.
