Post by repur71 on Sept 24, 2016 10:42:50 GMT -6
alright I'll try using my multi meter
Post by repur71 on Sept 24, 2016 1:29:22 GMT -6
so I've got an update i was recently driving my scooter and ran over a bump and my headlights came back on! but not even a second later they turned off. Any suggestions? what does this mean?
Post by repur71 on Sept 5, 2016 14:10:10 GMT -6
Im just gonna buy a new wiring harness if anyone knows a good website where i could get one just let me know
Post by repur71 on Aug 29, 2016 14:03:19 GMT -6
its a 2008 XINGYUE Eagle 150 (XY150T)
Post by repur71 on Aug 29, 2016 0:18:06 GMT -6
so i messed around with the light bulb connectors and still nothing, Im thinking its a bigger problem because the dash and headlights are both out
Post by repur71 on Aug 26, 2016 3:53:18 GMT -6
I'll try it
Post by repur71 on Aug 20, 2016 2:45:02 GMT -6
so I have a problem where my headlights and dash lights wont work, but tail lights and signal lights work. The night my headlights stopped working they would get brighter when I revved, then it went out. I changed my volt rectifier regulator yesterday still nothing i changed my stator about a month ago too
Post by repur71 on Jul 27, 2016 22:45:58 GMT -6
so my scooter is finally running after 4 months(thank god) i changed the spark plug and gas sprang up like flower. Thank you to everyone who contributed to this thread -repur
Post by repur71 on Jul 24, 2016 20:35:16 GMT -6
so i was thinking, i have compression, if it was a valve problem wouldn't i have no compression? or is this unrelated
Post by repur71 on Jul 24, 2016 14:16:00 GMT -6
thanks for the info i will definitely check
Post by repur71 on Jul 24, 2016 0:36:39 GMT -6
i have a 2008 xy150t four stroke, I have spark, Im checking my magneto because I'm just wondering if i should have it aligned a certain way when i put it on because my engine wont fire but I'm getting fuel and spark
Post by repur71 on Jul 23, 2016 17:18:29 GMT -6
so my engine isn't firing so I'm thinking my magneto isn't in sync. Im no expert so any advice would be appreciated on how to properly install/line up a magneto flywheel.
heres a picture I made of the marks on the side of the magneto what do they mean? which one lines up with the T
Post by repur71 on Jul 21, 2016 22:03:24 GMT -6
so i got the manifold vacuum nipple switched and i think it works every thing fits but the bike still wont start I got spark I got compression i got fuel spark plug is wet and carb bowl has gas in it any suggestions ?
Post by repur71 on Jul 17, 2016 23:23:04 GMT -6
I already have 4 way vacuum line connector but the vacuum line isn't working because the manifold vacuum is sealed off
Post by repur71 on Jul 17, 2016 20:19:18 GMT -6
Im gonna try replacing the nipple with the one off my old carb
