No Power
by: randyjaco - Aug 29, 2016 16:44:40 GMT -6
Post by randyjaco on Aug 29, 2016 16:44:40 GMT -6
I have a Verucci 150,which has been running OK. It starts quickly and runs smoothly. But when I twist the throttle the engine bawgs down. The max speed is a measly 26mph. The spark plug indicates it is running a little rich, but is properly gapped and clean. The plug is firing with a nice blue spark. I am getting good fuel flow to the carburetor. The fuel is fresh. The wiring is tight no evidence of grounding out. What am I missing?
Randy
No Power
by: jct842 - Aug 29, 2016 18:03:36 GMT -6
Post by jct842 on Aug 29, 2016 18:03:36 GMT -6
When was the last time the valves were adjusted?
No Power
by: randyjaco - Aug 29, 2016 18:24:29 GMT -6
Post by randyjaco on Aug 29, 2016 18:24:29 GMT -6
They were adjusted about a week ago. I bought this about 2 weeks ago. It was non-running. I cleaned out the fuel system/carb, set the valves, checked/replaced questionable hoses, redid brakes, new battery, replaced rollers and belt, changed fluids, checked exhaust system. I have since put about 200 miles on it. I cranked it yesterday and headed down the street and the problem started? I have a good amount of motorcycle experience. This is my first Chinese scooter.
Thanks Randy
No Power
by: jct842 - Aug 29, 2016 20:24:08 GMT -6
Post by jct842 on Aug 29, 2016 20:24:08 GMT -6
It still would not hurt to lift lift the valve cover and double check those valves.
No Power
by: randyjaco - Aug 30, 2016 12:01:13 GMT -6
Post by randyjaco on Aug 30, 2016 12:01:13 GMT -6
Thanks guys, I figured it out. It was the carburetor. A tiny piece of something was lodged in the main jet. When I looked at the jet in the light the hole was not round. I ran a #55 drill bit through it, put it all back together and problem solved ☺️ Randy
No Power
by: jct842 - Aug 30, 2016 12:41:15 GMT -6
Post by jct842 on Aug 30, 2016 12:41:15 GMT -6
When ever I hear about some thing in a jet I get wondering about the hoses and fuel filter. Both should be up for a change.
