Post by randyjaco on Sept 4, 2016 17:54:22 GMT -6
Riding at full speed or close to it for 5 minutes or more will cause my scooter to stall out. If I shut down the throttle, I will usually get a backfire, after a second or two I can usually resume speed for a short time. Otherwise the scooter runs well and as long as I don't do prolonged high speed running. I am assuming that it is a fuel starvation problem,but I haven't figured out a solution.
The back story is I bought this 2006 Verucci 150. It was not running when I bought it. Years ago I worked as a motorcycle mechanic, so I am not clueless. Long story short, I cleaned up the carburetor /fuel system, put in a new vacuum petcock and fuel lines, new spark plug, set the valves, New variator, new Kevlar belt and finally a performance CDI and performance coil. I also drilled a small hole in the gas cap.
Any thoughts on what I can do to eliminate the stalling Problem? Thanks Randy
Post by jct842 on Sept 4, 2016 18:45:28 GMT -6
more than likely you are running out of fuel. fuel pump likely the cause, at full throttle you have the least vacuum. a vacuum leak, just a slight one can be the root cause.
Post by crwford on Sept 4, 2016 21:41:50 GMT -6
I would check rubber intake for cracks
Post by randyjaco on Sept 5, 2016 16:51:36 GMT -6
Thanks Guys, That makes sense. I will give them both a look and replace the vacuum lines +T connector to boot. Looking forward to the day when I spend more time riding than fixing 😡 Randy
Post by randyjaco on Sept 6, 2016 9:53:13 GMT -6
You nailed it. It was a bad vacuum hose connection. It now runs at high speed with no hesitation. Thanks Randy
