Post by jren on Sept 3, 2010 12:00:08 GMT -6
Hello everyone
I am having a problem getting some lets to work on my scooter. I just installed a new battery
My headlights, dash board lights, and tail light wont work right. Everything else works great all the time. Occasionally they will all decide to come on at once for a short while. I have a volt meter and have detached most of the wiring harness but just dont know where to start. Any help is greatly appreciated.
Post by jhbietz on Sept 3, 2010 12:44:01 GMT -6
Kind of sounds like a ground problem. Find where all the ground wires are attached to the frame, remove the bolt, and clean everything with sand paper.
Post by jren on Sept 3, 2010 14:17:14 GMT -6
I have a 150cc scooter that says eagle on the side and has an aa powersports symbol on the front. I know it has the gy6 motor.
Its driving me crazy. It's something in the front where all the wires are. If i tap on the steering wheel or tug on a batch of wires it will go on but then If I tug or tap the same way I cant get it go off.
Post by jren on Sept 3, 2010 17:15:53 GMT -6
Bingo......one of the grounds must have not been making a good connection. I took apart a splice in the harness that had 10 green wires just below the steering wheel and now it all works.. A lot of the wires in the steering wheel part of the harness are spliced like this with a piece of solder holding them. I guess when you try to do this with 10 wires its not so reliable. thank you mr beitz.
Post by jhbietz on Sept 4, 2010 10:32:16 GMT -6
Glad you figured it out!
