Post by ScooterRider on Oct 20, 2010 7:03:47 GMT -6
I should know something went wrong when, my 250B stalled at the height of morning traffic in the middle of the 4 lane bridge! Frantically pushed my scoot to the 3 feet wide "shoulder" dodging some and thankful to the other motorists, allowing me safely cross 2 lanes. In the darkness not realizing what was the situation, I restarted my scoot and continued my commute to work 22 miles at the freeway speeds(65-75 mph). When I got to work, I noticed the hose on my oil collector was OFF! The place where normally the oil plug would be present, there was an open port staring at me. Consequently, I have lost ALL of the motor oil on the way to work. I know this, because it took a whole 1 quart to refill it. Thanks to the synthetic oil(in my humble opinion) there is no noticeable damage done. I did notice slight tapping noise.The engine temperature has never risen above the normal. I did take it for a test run and did not notice any performance deterioration. A note here: I think my scoot stalled because the pressure in the crankcase dropped suddenly when that hose popped. Any thoughts on this?
Post by madcollie on Oct 20, 2010 8:08:17 GMT -6
I should know something went wrong when, my 250B stalled at the height of morning traffic in the middle of the 4 lane bridge! Any thoughts on this? Yes, my first thought is: GLAD YOUR STILL HERE WITH US!Second thought: Thank the scooter gods and fix ride before your home trip. I'm sure you had that one too. M/C
Post by ScooterRider on Oct 20, 2010 8:35:09 GMT -6
thanks M/C :-)
Yoster aka "Matt"
Post by yoster on Oct 20, 2010 9:28:50 GMT -6
I want to start running synthetic in mine, but I'm a 'don't waste what you have' kinda guys. As such, I still have over a gallon of 15w-40 oil I got from Tractor Supply Co that I need to use up before I can go get synthetic lol.
Post by Cruiser on Oct 20, 2010 10:47:16 GMT -6
Well, that was a scary situation. You had a couple of things going for you. It was a cooler time of the day and maybe the synthetic oil helped protect the engine. Also, the low pressure oiling system on these scoots is more immune to interruptions in oil pressure.
Post by ScooterRider on Oct 27, 2010 11:39:42 GMT -6
AN UPDATE: I have replaced the synthetic oil with a quart of Slick-50. The initial slight "click" disappears in 10 seconds. Looks like I lucked out this time, and there is no apparent damage done to the engine...fiewwww! Still waiting for the heavier weights (15.5 gr) for the J.Costa variator to gain the top end speed.
