Senior Clinician
Yoster aka "Matt"
Post by yoster on May 9, 2012 17:17:05 GMT -6
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 20, 2011 17:51:59 GMT -6
Whew, craig, I think this whole thread is a bit old
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 20, 2011 10:39:35 GMT -6
So a quick update on this. Was riding to work this morning and experimented with my back brake. Apparently this whole time I haven't been grabbing the end of the bar.. so I didn't have the same leverage as I could have had this whole time. I think it's because the back lever is "harder" so I naturally "choked up" on it more (with it being "harder" the end of the bar was a stretch for my hand. Now I force myself to just reach further and use the end of the lever).
Anyway, lesson learned.
Senior Clinician
Yoster aka "Matt"
JCL 250cc
by: yoster - Jul 12, 2011 21:08:59 GMT -6
Post by yoster on Jul 12, 2011 21:08:59 GMT -6
Seems a little late for that question doesn't it?
This is a forum that carters primarily to Chinese scooters, so of course we're all going to cheer you on! You might get a different opinion somewhere else though. But regardless, welcome to scooterdoc!
These scooters all have their little quirks, but if you're the type of guy (or gal) that's comfortable with doing your own wrenching, then you'll be completely fine. We can get you through just about anything you might come across. Be sure to read all the sticky threads in the library about doing a proper PDI and whatnot. Very important!
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 12, 2011 21:04:05 GMT -6
Yeah I may consider eliminating the valve.. if it's easy. Cruiser, there definitely must be something up with my rear brake.. no way I can lock it up. I never thought much about it though.. on all the mountain bikes I've had (with disk brakes), the rear brake lever was always harder to press than the front.. I always just thought it was the nature of rear brakes. Next time I'm out I'll actually try to lock it up.. I thought I was on it pretty darn hard when this happened but who knows.. it all happened so fast! Definitely need to get it sorted out though.. it was not at all a good feeling and kinda caught me off guard. Don't think it would be a glazing issue (my scoot only has 1300 miles on it), but who knows.
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 12, 2011 11:01:56 GMT -6
I was always happy with the brakes on my scooter, until yesterday when I had to get on them hard for the first time. It was a situation we've all come across before.. driving down a road, light turns yellow and you're right between the "stop" point and the "try to beat it" mode. Not quite close enough to easily beat it, but, not quite far enough to stop easily. And of course I was going bit over the speed limit.
So decision time came, and knowing my scooter doesn't have much "umph" above 60mph (and therefore no way in the world I was going to beat this light), I decided to stop... or try to. It started braking well (both brakes applied hard), but as I applied more pressure... the braking force did not increase.. in fact it almost felt like it decreased! Front brake lever would go do down more, but no change in braking. I'm rapidly approaching the intersection thinking... I'm not going to stop! I grabbed my rear brake and squeezed (still keeping the front brake down) until I was about blue in the face, and I stop just past the double yellow crosswalk lines (good thing no pedestrians were crossing). Then I just walked it back behind the lines.
Frustrating thing was, I know I wasn't even CLOSE to locking up. In fact I've stopped MUCH quicker before when I applied LESS force to the front brake. It seems like once this "ABS" thing kicks in, it releases a too much of the braking force. It was braking hard though regardless... I could smell the brakes once I had finally stopped.. they were definitely hot. I'd say this was just brake fade, but it felt different than that.
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 11, 2011 11:32:19 GMT -6
What are you hoping to find by doing a compression test? Unless there is zero compression, the bike will start if everything else is working correctly. May not run the best, would smoke, but it would start.
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 7, 2011 23:00:50 GMT -6
If you're not getting 14.5 volts at idle with lights off, then your RR isn't keeping up. (assuming there's no other large drain somewhere). Yours is actually acting like mine did before I upgraded to the OMP RR.
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 1, 2011 10:03:19 GMT -6
Oh yeah and welcome to Scooterdoc!
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jul 1, 2011 10:02:56 GMT -6
When I first started reading this I thought, ahh, valves! Then as I read more I thought.. wait, no, they checked it. Then I thought, something in the CVT! Wait no... lol
Looks like the mechanic checked all the primary culprits for a diesel sounding scooter. My next guess would be that something is hitting somewhere. I.e.: In my scooter, due to the way these little motors vibrate, something on the carb is hitting this piece of metal, SOMEWHERE (I've never been able to determine), and it always makes a fast rappity-tap tap sound. If I put my hand on it or brace it so there's less vibrating, the sound instantly goes away.
Any chance you could post up a vid so we could see/hear?
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jun 29, 2011 13:12:57 GMT -6
When bhinch said "transmission" he was referring to the gears in the back-end, not the CVT. I used the same term to compare apples to apples, but then clarified after the first sentence that our transmission is actually a CVT.
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jun 29, 2011 9:46:13 GMT -6
Just a note ..... gear oil is not motoroil....I used 85W90 wt gear oil.....has been used for ages....the transmission knows the difference.....like strange noises coming from behind your seat.....will tell you..enjoy the ride.... Our scooters (Chinese scooters) do not have a transmission.. they're just gears in a static configuration, nothing else. Our "Transmission" is a CVT, which isn't even oiled either (which is why "motorcycle oil" does not benefit us one bit). 10-30, 10-40, or 75/90 gear oil will all work fine in the rear-end. Heck even pure Lucas Oil would probably be fine. You're just keeping light lube on the gears back there, a very very small amount. The gears in these China scoots really aren't doing that much work. If you want to play it safe (like I do), just go with 75/90. Also, take the Chinese recommendations with a grain of salt. Usually you say "go with OEM recommendation" ..... not necessarily the case with these China scoots lol!
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jun 28, 2011 21:02:13 GMT -6
Either is perfectly fine. 10-30 motor oil is actually of similar viscosity as 75-90 gear oil (you can't compare numbers directly across oil type..) The additives in car oil are null and void for the gears in our scooters, so it's a completely valid substitute. See the chart at the link below: www.vintagetriumphregister.org/maintain/oil-overview.shtml[edit] - Here's a good chart:
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jun 27, 2011 14:22:51 GMT -6
Senior Clinician
Yoster aka "Matt"
Post by yoster on Jun 27, 2011 14:18:21 GMT -6
What confusion? The 244 finds its way in the 250A more often than the 250B, but we've seen it in both. The letter isn't a sole indicator of the engine it has.
