Post by thetucks on Nov 28, 2010 21:37:43 GMT -6
Is there suppose to be oil inside the scooter starter? does anyone know? thank you.
Post by rapidjim on Nov 29, 2010 7:51:24 GMT -6
No
Widehide and the Wife
Post by widehide on Nov 29, 2010 8:12:03 GMT -6
If you are talking about the actual 12 volt starter motor, the answer is no. If you are referring to the Starter Clutch area, then yes that must have oil.
Post by thetucks on Nov 29, 2010 13:10:55 GMT -6
Yes im asking about the actual 12vt starter that wires to the solenoid. How would oil get in there?
Post by widehide on Nov 29, 2010 16:54:07 GMT -6
Its gear does mesh with a gear that in the engine case sits in oil, if the starter shaft o-ring is bad then oil can get inside the motor. Thats my best guess.
