Post by catrell92 on Jan 2, 2011 19:52:59 GMT -6
This bike has dual radiators btw, has to be the most annoying issue I have ever encountered because since day 1 if it hasn't been 1 thing its been another.for a while I had the overheating issue worked out around the time summer ended and it was probably because I removed the plastic, panel covering the lower radiator. The fans on this thing are real POS and someone suggested that I should get ATV fans because they have higher RPMs and are more durable. A couple of days ago I modded my bike because my lower radiator fan stopped working because of the poor wiring about 3months prior, I had ridden it with just the front radiator fan with no problems , I already tested the thermo switch and it worked like its supposed too. I bought a 12v clip on cooling fan ( car accessory) from rite aid and tore it all apart and clipped the wires so it could plug in my exisiting lower radiator plug and mounted it by drilling a 3/16th hole in the frame and adding a bolt and nut to hold it on, I wasn't intened for this kindof use ut IMO the RPMs are better than my original fan, everything worked out perfectly. 2 days before that I even purchased a new radiator cap with a higher PSI rating and flushed coolant, ran prestone coolant cleaner then redrained and filled with a 50/50 mix of prestone, to my knowledge I believe I burped it correctly because I replaced the thermostat after running withut one for 2-3 months because my initial thought was that it'll run cooler, I just replaced it just to be safe so everything would be balanced out in the cooling system. As I watched the bike idle s a test, the fans would cycle on and off alternately so I guess that's a good sign that I did everything correctly from the burping stand point. Ill have to re-open the radiator cap just to make sure its topped off though. Today I got that eeery annoying high pitched beep ( aka the overheating indicator) someone. Could idling have caused it to overheat, I. Left it on the centerstand for about an hour while I went in and out of the house and checked on it periodically, I even made air scoop mods so it could get better airflow, I haven't test driven it yet though, only have let it idle as I use this for my test runs. The reservoir tank did have a little more coolant after it overheated than before it did btw, usually if it overheated. The tank would start overflowing and leaking through the seal which I siliconed yesterday lol it definately withstood a lot longer though. The reason I was so motivated to doing his btw was because after testing this particular antifreeze I had bought from and the gas station and was currently using before this, I literally watched it turn into frozen ice chunks in my fluid drainage bucket, this almost killed my bros motor on his crown vic!! I had to dump that POS ASAP
Post by ccprof on Jan 4, 2011 5:52:38 GMT -6
After reading all the posts about the Storm and overheating problems, I can't help but wonder if the cause isn't the double radiator. Is there anyway to remove the doubles and put a single radiator of a size equal to the sum of both or even a little larger? Maybe something off a trashed scoot or even a cruiser?
Post by kz1000st on Jan 4, 2011 6:48:24 GMT -6
In a word-Yes. I left the Big Ruckus on the centerstand for twenty minutes and got an overheat light and water blew out the overflow tank. I let it cool off for an hour, refilled the tank and rode it for twenty minutes without any problem. Fans only cover a piece of the radiator, blowing air covers all of it. Besides the amount of air that moves from motion will exceed the amount a fan can create.
Post by catrell92 on Jan 4, 2011 23:02:39 GMT -6
After reading all the posts about the Storm and overheating problems, I can't help but wonder if the cause isn't the double radiator. Is there anyway to remove the doubles and put a single radiator of a size equal to the sum of both or even a little larger? Maybe something off a trashed scoot or even a cruiser? I believe that is the main case, andif it still overheats I'm removing the 2nd radiator.would 1 radiator in the front fairing be too long of a distance though?
Post by ccprof on Jan 5, 2011 7:06:10 GMT -6
Beats me. That's where most radiators are tho. Let's see what others say.
