Post by mctojs on Jun 3, 2011 2:03:42 GMT -6
Hello Guys! I'm posting a video on my kymco super 8 speed test... May I ask whats your comments and recommendations on how can I improve my CVT... heres my set up... heres my cvt set up.. racing pulley 11x13 roller weights 1k rpm clutch sprng 1.5k KOSO CS stock TD yamasida clutch and bell stock tires, front and rear 100x80x14(front)120x80x14 stock air filter 104 jettings 84 kilos rider here's the video... it only reached 110kph thanks a lot...
Post by Bashan on Jun 3, 2011 3:55:02 GMT -6
110 KPH = 68 MPH, that's haulin' arse on a scooter. The speedo wrapped right around too, the bike accellerated quickly. I'm not sure you need to tweak more out of it but what the hell. I'd be interested to see your RPMs as it accellerated and then at top end, that might provide valuable data.
Post by sprocket on Jun 3, 2011 9:48:01 GMT -6
That's a Chinese speedo you should verify that speed by GPS if you are into that stuff...... Kymco's are better quality but the speedos are still usually fast...
Post by mctojs on Jun 5, 2011 23:29:41 GMT -6
110 KPH = 68 MPH, that's haulin' arse on a scooter. The speedo wrapped right around too, the bike accellerated quickly. I'm not sure you need to tweak more out of it but what the hell. I'd be interested to see your RPMs as it accellerated and then at top end, that might provide valuable data. thanks sir... actually i'm testing how fast can my modified scoot can achieve...i usually run my scoot on a city ride, usually a stop and go ride... previously I hit a 120kph on a long strech, and since then i barely reached that speed... yesterday, i tested again using 800 rpm CS..and here's what happened... unfortunately I don't have tachometer on my scoot..Thats why I cant give any data on its RPM..
