Post by mctojs on Sept 2, 2013 7:19:49 GMT -6
Post by mctojs on Jul 27, 2013 7:22:15 GMT -6
Good Day Guys! May I ask from you guys, procedure in repairing the Starter Bendix drive for Kymco scooter. . Thank you and more power!
crankshaft
by: mctojs - Jan 22, 2013 16:20:58 GMT -6
Post by mctojs on Jan 22, 2013 16:20:58 GMT -6
Thank you very much sir Alleyoop. . . I really don"t see any washer/spacer between the gear and bearing .. Do you have any idea where that thing should be placed?
crankshaft
by: mctojs - Jan 22, 2013 10:01:21 GMT -6
Post by mctojs on Jan 22, 2013 10:01:21 GMT -6
Good day everyone! may I request for your input regarding this problem I have... Recently i replaced my crank bearing, but I noticed a side play after its installation. . . I suspected this culprit. . a misplaced washer/spacer. . is this washer in right position? DSC01382 by tojobriva, on Flickr is it really between crank bearing and timing chain sprocket or placed between the bearing ang crank. . Thank you very much!
crank play
by: mctojs - Jan 12, 2013 18:33:39 GMT -6
Post by mctojs on Jan 12, 2013 18:33:39 GMT -6
Good day guys. . . i just recently replaced my crank bearning and after rebuilding my engine i noticed this play on my crankshaft, just like in this video. . .
is it normal? thank you so much!
Post by mctojs on Sept 24, 2011 18:59:08 GMT -6
Thanks a lot guys! I really appreciate your inputs!
Post by mctojs on Sept 22, 2011 23:31:53 GMT -6
thanks guys... another thing, my scoot is actually modified with big bore kit.. originally it is 125cc...
Post by mctojs on Sept 22, 2011 21:48:56 GMT -6
Thanks a lot sir sprocket... actually i set my valve gaps at .003 intake and .004 exhaust... by the way im using 58.5 chromebore... Is the 155 to 165 psi compression good for long ride?
Post by mctojs on Sept 22, 2011 18:44:51 GMT -6
Hello guys.... May I ask for your technical expertise on my problem on how to increase the compression reading of my KYMCO SUPER 8? Recently, I tested it and reads 130PSI.. then I dropped some oil, and tested it again and it reads 140? is it OK? And how to increase the compression of my engine the safe way?
Post by mctojs on Jun 5, 2011 23:29:41 GMT -6
110 KPH = 68 MPH, that's haulin' arse on a scooter. The speedo wrapped right around too, the bike accellerated quickly. I'm not sure you need to tweak more out of it but what the hell. I'd be interested to see your RPMs as it accellerated and then at top end, that might provide valuable data. thanks sir... actually i'm testing how fast can my modified scoot can achieve...i usually run my scoot on a city ride, usually a stop and go ride... previously I hit a 120kph on a long strech, and since then i barely reached that speed... yesterday, i tested again using 800 rpm CS..and here's what happened... unfortunately I don't have tachometer on my scoot..Thats why I cant give any data on its RPM..
Post by mctojs on Jun 3, 2011 2:03:42 GMT -6
Hello Guys! I'm posting a video on my kymco super 8 speed test... May I ask whats your comments and recommendations on how can I improve my CVT... heres my set up... heres my cvt set up.. racing pulley 11x13 roller weights 1k rpm clutch sprng 1.5k KOSO CS stock TD yamasida clutch and bell stock tires, front and rear 100x80x14(front)120x80x14 stock air filter 104 jettings 84 kilos rider here's the video... it only reached 110kph thanks a lot...
Post by mctojs on Apr 5, 2011 23:41:33 GMT -6
hello manoy! nope, i'm the one with red shirt..
Post by mctojs on Mar 24, 2011 2:35:42 GMT -6
Post by mctojs on Mar 15, 2011 1:40:36 GMT -6
very beautiful pics and storie here, must have been a thrill of a lifetime. the volcano pics looks so freging cool thanks Sir! yah, the volcano is really cool..except during eruption and heavy rains....
Post by mctojs on Mar 15, 2011 1:36:17 GMT -6
Absolutely beautiful country. The whaleshark, as I recall, is harmless, sort of a baleen eater like some whales, right? Great shot of him!! Looks like you have a very active club. What makes of scoots are you riding? hello sir.. indeed we have a very active club here in the Philippines! We explore our country through riding/ adventure with our scoots.. Its a KYMCO SUPER 8 125cc.. But most of us modified it to 155cc by installing a 58.5 borekit... The whaleshark is a harmless fish..its a fish not a mammal..
