Post by losmandeals on Jul 29, 2011 19:39:27 GMT -6
stripped down Attachments:
Post by stewali on Jul 29, 2011 22:06:34 GMT -6
Oyes been there, have you gotton the front off? the turn signal help hold the front on so don't break them.
Post by sarge707 on Jul 30, 2011 15:51:47 GMT -6
Ok I have got every thing off my reverse trike rear wheel except the black right swingarm piece that connects to the axle. It will move back and forth but how do I get the wheel off? The center hole fits a hex bolt BUT is that the way because I don,t want go round out that hole. Attachments:
Post by stewali on Jul 30, 2011 16:38:25 GMT -6
I don't know, never been there. Have you tried some of the how to section on the fourm, If you get it done tell us. Just on a side note I'm fixing a friends Vespsa GT200 getting parts for that is just as bad as getting parts for our scooters.
Post by Alleyoop on Jul 30, 2011 16:39:31 GMT -6
That is probably what has to come out it holds the Disc against the wheel. Alleyoop
Post by losmandeals on Jul 31, 2011 20:11:33 GMT -6
Sarge did you get your free helmet yet? still waiting on mine
Post by sarge707 on Aug 1, 2011 11:39:21 GMT -6
I have 6 helmets-I told him to keep it.
Post by sarge707 on Aug 3, 2011 15:24:13 GMT -6
Got tire changed and putting back on BUT Brake caliper seems to be stuck closed Sooo how do I get it open so it will go over disc??
Post by turtle8 on Aug 3, 2011 23:42:36 GMT -6
Do you mean the brake piston(s) has come out a bit? If so, you can try pushing it back in with a C-Clamp, that is what I do with car brakes.
Post by sarge707 on Aug 4, 2011 10:04:40 GMT -6
Yeah- I opened the bleed valve and oil reservoir and still no luck with the piston? Gonna get the C clamp and have to rebleed the lines BUT I ,m learning and in no rush. Gonna find some video,s on this~!
Post by sarge707 on Aug 6, 2011 10:43:36 GMT -6
Air compressor and WD40 got the pads open. Thanks!
Post by stewali on Aug 9, 2011 15:09:18 GMT -6
hows the new wheels working out? I have new fronts on order.
Post by sarge707 on Aug 9, 2011 15:17:11 GMT -6
Hope to ride soon , will check the back tire after I get he pipe back on.
Post by losmandeals on Aug 12, 2011 21:31:31 GMT -6
Okay so someone came to buy the extra trike that i bought. while showing the how it tilts went to engage the the upright lock and the cable snapped!! so of course they did not want it and it is impossible to find the same one since warranty does not cover it. this thing is killing me if its not one thing its another. anyone else check to see if they had a head gasket?
Post by losmandeals on Aug 12, 2011 22:04:15 GMT -6
hopefully rapid jim can help me out Attachments:
