Post by hardcandy on Jul 16, 2011 17:05:57 GMT -6
I need help with a carb on a Peace 150 scoot it seems as if the float may be sticking when we run the scoot for a bit it will stall out and leak gas from a tube thats attached to the bottem of the carb. If we let it sit for a min it will start back up and run for a bit and do the same thing. Much thanks.
Post by sprocket on Jul 16, 2011 17:12:36 GMT -6
That is the float drain tube.. there is a screw either on the end of the drain tube or on the side of the float bowl.. it is loose and needs to be tightened... Attachments:![](//storage.proboards.com/3059616/thumbnailer/SlbnDH9WqOjExa_QDmiZ.jpg)
Post by ncredleg on Jul 16, 2011 17:54:33 GMT -6
Hey bud.I have seen the resolution for that on here , but I can`t remember what it was ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) You should be able to do a search for the specifics of your leaking carb and come up with it.Hope that helps.Russ Ooops! Sprocket got it.
