Senior Clinician
Post by ncredleg on Dec 21, 2011 14:24:57 GMT -6
Does that scoot have a leading link front end on it? I don't know if my terminology is correct but I think this would be called a trailing link suspension. The fork is frontmost anchoring the link pivot. It is followed by the shocks and the front axle is on the end of the link, farthest from the link pivot. Make sense? You are right,I was looking at wrong
Senior Clinician
Post by ncredleg on Dec 20, 2011 23:16:02 GMT -6
Senior Clinician
Post by ncredleg on Dec 19, 2011 23:28:05 GMT -6
I am going to check out a place that has alot of scooter parts tomorrow from wrecked scoots , etc.I can take pictures of what he has with the 19 spline. Most 50cc only have one shock and mount on the left side, so that should not be an issue for the right side bracket.
Senior Clinician
Post by ncredleg on Dec 10, 2011 23:43:19 GMT -6
Has anyone on this board bought from this company? I have been reading good things on other boards about them and was curious if anyone here bought from them? www.jiangwayne.com/scooter/index.php
Senior Clinician
70 mph?
by: ncredleg - Dec 10, 2011 6:46:07 GMT -6
Post by ncredleg on Dec 10, 2011 6:46:07 GMT -6
Ncredleg, PM TVNACMAN you probably will pay less than I DID. It is a 107mm Variator which will fit the 150s, that is the largest you can fit. The OEM they come with are usually about 1/2 inch in diameter smaller. the 107mm measures 4 1/2 inchs across so measure yours, it will probably come in just a hair over 4 inchs. Alleyoop Thanks for the link, Alley.
Senior Clinician
Post by ncredleg on Dec 9, 2011 8:49:13 GMT -6
That is a 150cc 2 stroke, w/4 speed manual? Man!, there are all kinds of go-fast things you can do to that beauty!  ;D
Senior Clinician
Post by ncredleg on Dec 3, 2011 16:47:54 GMT -6
Thank you Rich. This is the board that I go to for good answers and grown-ups.I really appreciate the guys on here. For any insanity I hang out on Moped Army`s Off Topic forum. Over here , I feel like I could invite any of the guys and ladies into my home and we would have a great time.
Senior Clinician
Post by ncredleg on Dec 2, 2011 22:45:53 GMT -6
I like those Honda Gyros. The home market gets one with a250cc engine ;D . That would be so sweet!
Senior Clinician
Post by ncredleg on Dec 2, 2011 1:43:31 GMT -6
Don`t know how that happened.I thought that was a link to a custom trike from Japan.I deleted it and will try to find the correct video.Sorry about that.Here is the correct video:
Senior Clinician
Post by ncredleg on Dec 2, 2011 1:10:39 GMT -6
I need to say this for my peace of mind.In a prior post I remarked upon how relevant and definitive this site is for info on our scoots. Now , I need to speak about my recent perceptions on the interaction here.We, as a group have, by and large gotten along quite well with each other, but I am beginning to see more and more posts that degenerate into flames. None of it is necessary, not all of us have the same experience, knowledge or finances.That`s all.
Senior Clinician
70 mph?
by: ncredleg - Dec 2, 2011 0:29:03 GMT -6
Post by ncredleg on Dec 2, 2011 0:29:03 GMT -6
And that is a FACT JACK. That Variator has a good low end ratio and good top end. I ran it with the 13gram rollers first cause that is what it came with. Okay, so , what is this variator and where can I get one.
Senior Clinician
Post by ncredleg on Nov 30, 2011 22:58:13 GMT -6
I want to acknowledge everyone`s input and camaraderie.I`ve met some good folks on here and definitely had some serious questions answered on my scoot. I have been working on the carb , making a new intake and lost the pictures that I took of the vac and fuel line locations. Guess what , they were already posted here in the Library with tags .You can`t beat that kind of info . Thanks. ;D
Senior Clinician
Post by ncredleg on Nov 18, 2011 10:42:59 GMT -6
Senior Clinician
Post by ncredleg on Nov 3, 2011 8:08:07 GMT -6
Have`nt read all of the posts but take the battery to an AutoParts place like O'Reilly`s or AuotZone or Advance. They can put it on the tester for free.It will tell you what it`s state of charge and whether it is any good.
Senior Clinician
Post by ncredleg on Oct 27, 2011 6:55:08 GMT -6
Has anyone installed their carbs facing front? What issues have you had with it? I was told by a company that I could not use the stock manifold because it would tilt the fuel bowl incorrectly and starve the carb. Does anyone know if this is the case? I really need to know ,this is holding me up. Thanks in advance,Russ
