Post by ploit on Oct 8, 2011 17:32:17 GMT -6
SCOOTER WON'T START STRONG CRANKING ....LIGHTS OR RADIO DOES'NT COME ON BATTERY FULLY CHARGED..SCOOTERS WATER-COOLED IT'S NEW HAS ONLY (363 MILES) ALL FLUID LEVELS ARE CORRECT...SPILLED CONTAINER OF OIL AND ANTIFREEZE IN UNDER SEAT IT DRIPPED ONTO RELAY BOX,,GOT FULL TANK OF GAS ATFER INSPECTING RELAY BOX DISCONNECTED BOX THEN WIPED IT OFF ..RECONNECTED BOX NOW BUTTON WHILE DEPRESSING BRAKE (KILL SWITCH OFF) SCOOTER WON'T CRANK....PLEASE ADVISEI
Post by flyawaydoug on Oct 8, 2011 18:07:45 GMT -6
There is a fuse in the relay connector. Check that first.
Post by ploit on Oct 8, 2011 18:49:39 GMT -6
WHERE IS FUSE...IN THE RELAY CONNECTER IS THAT DIFFERENT FROM THE SINGLF MAIN FUSE HODER IF SO WHERE IS IT LOCATED ..ANY PIC'S OF IT'S LOCATION
Post by Alleyoop on Oct 8, 2011 18:54:56 GMT -6
I believe they are in the front someplace maybe in the GLove box. Alleyoop
Post by ce on Oct 10, 2011 11:17:08 GMT -6
There's an access panel at the back of the seat bucket to get to the fuse box, and tail lights.
You already checked the fuse next to the battery, nicht?
Live To Ride / Ride To Live
Post by richardthescooter2 on Oct 10, 2011 11:30:00 GMT -6
That kill switch has to be on for scooter to start, check out your CDI make sure all wires are connected.
