Post by mike6736 on Dec 10, 2011 16:50:23 GMT -6
Ger...Yes to both your questions
Mike
Post by ger42 on Dec 11, 2011 10:17:27 GMT -6
Step 1 of the stator removal is done the muffler is off. Exhaust ID is .9 inches one of the extended flange hit the frame I'll need to grind it down. Step 2 drain oil. Step 3 remove cover. Found no gasket available it's on back order got be careful taking the cover off.
Post by ger42 on Dec 11, 2011 14:26:02 GMT -6
I dumped the oil and all of this came out. What is sequence? Spring then plug followed by plug? As the plug I released from the case I saw the screen then everything got covered with oil. I ended up with just the plug in my hand. Screen and spring were in the catch tray. Is this how it goes back?
Post by mike6736 on Dec 11, 2011 14:53:22 GMT -6
Nice find Ger...Yes it looks like an easy fix, I was thinking pull fly wheel and all...Let me know how it goes if you go there
Mike
Post by tvnacman on Dec 11, 2011 15:06:31 GMT -6
pick up the spring and filter (leave the cap) turn it over . the small part of the spring fits in the cap .
Post by ger42 on Dec 11, 2011 15:24:07 GMT -6
This correct?
Post by tvnacman on Dec 11, 2011 16:31:09 GMT -6
yes
Post by ger42 on Dec 12, 2011 11:40:45 GMT -6
Cover is off. Stator comes off with it. Too easy at this point. Waiting for the hammer to fall.
Post by Alleyoop on Dec 12, 2011 12:39:01 GMT -6
What is that oil doing in there isn't that supposed to be a dry area? Alleyoop
Post by rapidjim on Dec 12, 2011 14:25:12 GMT -6
What is that oil doing in there isn't that supposed to be a dry area? Alleyoop No on the 300 it is a wet stator. Jim
Post by Alleyoop on Dec 12, 2011 16:01:10 GMT -6
WOW!! you would think it would cause shorts. Alleyoop
Post by ger42 on Dec 12, 2011 16:06:34 GMT -6
What is that oil doing in there isn't that supposed to be a dry area? Alleyoop Sorry I couldn't hold it and that was the closest thing. I have got to drink more water it't too dark.
Post by mike6736 on Dec 12, 2011 16:07:24 GMT -6
Wow, I too would have thought it would be dry. At least it is easy to get to
Mike
Post by rapidjim on Dec 12, 2011 16:15:40 GMT -6
More like some of the Japanese stuff, wet stator and since the coils are coated it doesn't short. Just like the oil filled transformers on poles outside your house. Stators generate power by magnetism cutting a coil. education.jlab.org/qa/createenergy_02.htmlJim
Post by mike6736 on Dec 12, 2011 16:19:44 GMT -6
Good info Jim. I have to say if I opened mine and seen that I would have said Oh @#$%... Ger sure has paid his dues... I hope to hear soon of him out enjoying that Magnum. I sure have had a lot of good times with mine
Mike
