Post by ce on Feb 12, 2012 18:54:55 GMT -6
Having too much oil in the engine will cause a cold bog.
With the scooter level and on the center stand, the dipstick is inserted without screwing it in, and the oil level shoul be in the middle.
If it's full of oil, drain some out, it should only hold a little less than a quart.
Post by Alleyoop on Feb 12, 2012 20:12:09 GMT -6
COOL!! Yep when cold and the ENRICHER is active it will run on the rich side and not be to responsive but it should be fine within 3-4 minutes that is about what it takes for the ENRICHER to shut off the extra fuel. What I do is Put the Choke on start it up and as it is warmning up for a few minutes I will be putting on my Helmet and gloves, checking that all my lights works turn signals etc and then I get on shut the Enricher off and away I go. Alleyoop
As far as the weights , tell us how high your rpms go and what is your top end speed and how it acts and we can then get your cvt tuned better to your likeing. Alleyoop
