Post by Alleyoop on Mar 22, 2012 21:11:55 GMT -6
Damn! Well try the Kill switch wire on the CDI. Now some like mine I can put the kill switch on and hit the start button it will turn the motor over but no spark to the spark plug. On some with the kill switch on it will not even crank the motor over. Alleyoop
Post by cashflow on Mar 22, 2012 23:01:01 GMT -6
if the killswitch is bad . will the head lights still come on and the tail lights.but no horn.or no turn signals. and the gas gauge dont work..
Post by tvnacman on Mar 23, 2012 3:59:44 GMT -6
then its ground in the area by the handle bars , check the key switch
Post by cashflow on Mar 23, 2012 10:40:29 GMT -6
how di i check the key switch?
Post by tvnacman on Mar 23, 2012 11:58:57 GMT -6
How many wires are on the key switch
Post by Bashan on Mar 23, 2012 14:09:22 GMT -6
how can i post a pic of my scooter ? Click here to see how to post pictures. By the description of what's working I'm assuming you have the vertical engine? In any event, I agree with John that it's a ground issue. Most of the things you listed run off of the black wire. If it wasn't working all of those things would be out, not some of them. The fact that just some of them don't work indicates a ground issue with those components. You'll have to pull some plastic and get wires exposed to do testing. Rich
Post by cashflow on Mar 23, 2012 16:09:58 GMT -6
cant find the wires.on the key switch...
Post by LUKE on Mar 23, 2012 21:04:46 GMT -6
cashflow, scooters are only manmade, dont get intimidated by it. if you know how to add 1+1 then for sure you can fix your scooter..lol
remove all those plastics and you'll see the key or kill switch wires....good that those wires weren't snakes, otherwise it would've bitten you already...LOL,,,,you know im kidding...well hope you fix your scooter fast,spring is almost nearing end...
Post by cashflow on Mar 23, 2012 21:09:15 GMT -6
will try to get to them later.hope i can fix my ride..
Post by cashflow on Mar 23, 2012 21:12:17 GMT -6
what plastic pices are you talking about?
Post by Bashan on Mar 24, 2012 2:57:23 GMT -6
The body plastic.........you can also check any components on the handlebars that are exposed.
Post by tvnacman on Mar 24, 2012 6:42:38 GMT -6
cash , sometimes strange problems take more trouble shooting . sometimes auto repair shops can't fix every problem , then you need to bring it to another shop . Just because you get a quick responce , does not mean it is on the right track . Several here have offered some good items to check it seems as your not making any ground . I not a fan of pushing work away , but it does happen . Cyberspace trouble shooting is very tricky , I don't know your scooter at all . I'm sure someone out there has worked on your scooter and knows it very well your best bet is to keep looking for other sources of trouble shooting help . Its not nice to direct someone to another forum , so I play nice . I have a Vespa if I have a problem with it I would be likley to look in a Vespa forum , there are quite a few , as there for the chinese .
08 roketa special edition 150
Post by roketafan on Mar 24, 2012 8:07:10 GMT -6
i would say this is a gy6 forum here and few dam good mechanics i have 30 yrs exp here and john makes a good point
Post by Bashan on Mar 24, 2012 8:18:48 GMT -6
I agree John, cybertroubleshooting is problematic but it takes some activity on both ends of the wire. The guy didn't take the time to answer Speedracer's query about what kind of engine he has or take *Lukes* advice about pulling the plastic. There's a link for posting pictures but we're still without images. These things aren't rocket science and they can be worked through with a little effort. You want to direct him to another forum? Fine, send him a PM, I'm sure he's been trolled already anyway. Rich
Post by justbuggin on Mar 24, 2012 8:29:16 GMT -6
just for kicks try putting the scooter on the center stand and make sure the side stand is up see what happens
