Post by cashflow on Mar 22, 2012 14:44:40 GMT -6
![>:(](//storage.proboards.com/3059616/images/oR2kmC5__XnKpfSYkzTP.gif) my scooter wont start..the head lights will come on and they back lights will work .but i cant get they turn signals will not work.and the horn wont wonk.and gas gage wont work.I tried both brake handles and still wont start. i put a screwdriver on the two large terminals on the starter relay and the starter spins over... ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) its a bronc 205 jonway.. 2007
Post by Alleyoop on Mar 22, 2012 15:08:36 GMT -6
So from what you are saying is that when you push the Start button it DOES NOT SPIN your starter. Just to make sure DO YOU HAVE the Killswitch on the RUN position, it happens to a lot of use once in a while. We forget to flip it to the run position. Alleyoop
Post by cashflow on Mar 22, 2012 16:30:24 GMT -6
yea kill is in the run position.
can my killswitch be bad?
Post by speedracer on Mar 22, 2012 17:45:40 GMT -6
Do you have the Honda or Yamaha clone engine in it?
Post by Alleyoop on Mar 22, 2012 17:50:27 GMT -6
Yes it can be a bad switch, But you can eliminate it by pulling the KILLWIRE off the CDI and trying it. Now if you do not get anything when you push the start button and the starter spins when you jump the terminlas on the Relay then it could also be your Relay that is bad as well.
When you press the start button does it make a CLICKING SOUND if so your Relay is bad? Also you can try and give the relay a little smack with a piece of wood or something the contacts may be stuck IT HAPPENS and see if it then works.
ALSO JUST want to make sure WHEN YOU SQUEEZE the brake handle or handles The STOP LIGHTS DO COME ON?
Alleyoop
Post by cashflow on Mar 22, 2012 18:29:43 GMT -6
no clicking sound. how do you try the killswitch and can i buypass it ? no brake lights .butr i dount have any emg lights and no horn and no turn signals and no gas gauge.all i get to work are dash lights and head lights and back lights... when i pull the brake lever i can hear a fint click in the handle so i think the brakr switch is working...
Post by cashflow on Mar 22, 2012 18:33:10 GMT -6
hey i did not tell you haw this happend iu wen t to the store with my wife.she went in the dtore i stayed out side on the scoot.when she was done and come out of the store.i pushed the scooter to were is came out of the store then the scoot would not start .it run fine up till then.
Post by Alleyoop on Mar 22, 2012 19:39:38 GMT -6
Yes you can bypass the Killswitch, But when you squeeze the breaks YOUR STOP LIGHTS SHOULD COME ON, that is what sends the juice to the RELAY so the start button works. Did you check the FUSE on the POSITIVE WIRE cable coming off the Battery, ALso check the RELAY it may also have a Fuse on it as well. But here is your CDI and you will have to pull the KILLSWICH wire OFF the CDI. That will bypass the Kill Switch being stuck on. Alleyoop ![](http://i813.photobucket.com/albums/zz56/als01seville/ALS-TRIKE/CDI_Pinout-1-1-1.jpg)
Post by tvnacman on Mar 22, 2012 20:04:15 GMT -6
I can fix it replace the fuse , nothing works!!!!!!!!!!! Jumping the starter relay engine will crank starter is good , if its dc cdi it won't run even if you jump the starter relay .
08 roketa special edition 150
Post by roketafan on Mar 22, 2012 20:09:23 GMT -6
fuse at batt johns right on there
Post by cashflow on Mar 22, 2012 20:14:22 GMT -6
DC CDI ![???](//storage.proboards.com/3059616/images/uQfospbezE7IcMUG1AtY.gif) ? what is the dc cdi? checked all the fuses. all good.could it be a bad grond wire.
Post by cashflow on Mar 22, 2012 20:15:39 GMT -6
will the killswitch be on all the time if i buy pass it?
how can i post a pic of my scooter ?
in line fuse good
Post by Alleyoop on Mar 22, 2012 20:21:12 GMT -6
The Kill switch will NOT FUNCTION anymore if you pull the wire off the CDI. So you will not be able to Kill the motor with the Kill Switch with the WIRE OFF THE CDI. If that is it then when you get or fix the switch you can always reconnect the WIre BACK on the CDI and you will then have the KILLSWITCH in operation again. But if you pull the KillSwitch Wire OFF the CDI and still doesn't fire then THAT IS NOT IT.
I still think its your FUSE to tell you the truth if it clicks when you squeeze the breaks. The Fuse MAY LOOK GOOD but be bad I would replace the fuse. Alleyoop
Post by cashflow on Mar 22, 2012 20:23:10 GMT -6
i will relace my fuse right now..be back with more news.
Post by cashflow on Mar 22, 2012 21:01:50 GMT -6
in line fuse replace still no luck
