Senior Clinician
08 roketa special edition 150
Post by roketafan on Jun 30, 2012 16:40:23 GMT -6
think needs a litttle brk in time letter rip for about 20 miles checkn oil mind you itll be fine or in manufactoring they did something to the oil rings
Senior Clinician
Post by roketafan on Jun 30, 2012 16:35:45 GMT -6
well still runing lean i think at wide open throttle and open exhaust, it breaks up sputters a little.i think the rad hose is to soft and claspses
Senior Clinician
Post by roketafan on Jun 30, 2012 12:31:53 GMT -6
the brace with get the carb level, throttle works fine
Senior Clinician
Post by roketafan on Jun 30, 2012 8:04:09 GMT -6
hows this look fellas still have to make a stable mount i cn still pull the carb down to get it a little more level
Senior Clinician
Post by roketafan on Jun 29, 2012 17:08:29 GMT -6
yup check all connections and fuel ,air fuel compression and spark she'll run
Senior Clinician
trans gears
by: roketafan - Jun 29, 2012 17:04:45 GMT -6
Post by roketafan on Jun 29, 2012 17:04:45 GMT -6
wow wonder u didnt crash hard i crashed mine 2weeks a ago hit a little patch gravel concussion and 12 hrs later i woke u scoot little cracked up so i just donated the plastic from my other scoot kept riddn
Senior Clinician
Post by roketafan on Jun 29, 2012 16:55:00 GMT -6
how was the stretch done im looking to do a fat rear wheel
Senior Clinician
Post by roketafan on Jun 29, 2012 10:08:43 GMT -6
Ill get some up aftr work I wprk 10 hrs with a pavn crew its a aluminum perf 30 mm intake and yes I removd spacer still hits crossbar ![](http://i1225.photobucket.com/albums/ee400/stanger1974/095.jpg)
Senior Clinician
Post by roketafan on Jun 28, 2012 19:33:54 GMT -6
yes the sprocket has seen it all at aleast i think
Senior Clinician
Post by roketafan on Jun 28, 2012 19:30:41 GMT -6
filling to the top can be a no no
Senior Clinician
Post by roketafan on Jun 28, 2012 19:28:50 GMT -6
cant get these all alum intake to fit right just no room any suggestion pl Ty
Senior Clinician
Post by roketafan on May 13, 2012 8:23:35 GMT -6
Be sure to check valve gap could a little tight from factory
Senior Clinician
Post by roketafan on Apr 30, 2012 23:18:18 GMT -6
no problems here from scrappydog here great prices fast shippn
Senior Clinician
Post by roketafan on Apr 30, 2012 23:15:48 GMT -6
solenoid .....
Senior Clinician
Post by roketafan on Apr 30, 2012 23:11:01 GMT -6
ran low on oil when case broke scorched piston looks like its going to need the block maybe u can get a short block
