Post by Alleyoop on Apr 7, 2012 0:15:38 GMT -6
Yes all that you said happens can be caused by the Valves being to tight. Adjust them to TOP INTAKE Valve .004inchs and BOTTOM EXHAUST to .005inches. Right now it is running LEAN if it is backfireing. So after you adjust the Valves it still backfireing then you have an AIR LEAK somewhere and it is sucking in to much air.
SO ADJUST the Valves and then tell us how it is running. Alleyoop
Post by tvnacman on Apr 7, 2012 9:14:04 GMT -6
check the wiring to the enrichener . Valves give hard starting . John Hello I agree with the valves , but it starts good cold then dies out and is back firing through the muffler . ENRICHNER!!!!!!!!!!!!!!!!!!! staying too rich!!!!!!!!! or is there gas in the vac lines ? Pull the spark plug and post a pic of it lets read the plug !!!! John
Post by kaka20 on Apr 7, 2012 11:21:46 GMT -6
today i take my trike to workshop they...checked..they opened the stator plate and tell me that it is burnt...the spring wraped around two coils where totally black in color..the above picture is not of the real stator plate but it looks same as in my trike... same happened in workshop after 10-15 minutes scooter stop starting even with a kick....they say we will fix it tomorow...i told him about checking the values but they say first scooter should pass current...then we will see the next problem... Attachments:
Post by kaka20 on Apr 7, 2012 11:30:52 GMT -6
looks like this Attachments:
Post by kaka20 on Apr 9, 2012 3:09:13 GMT -6
if any one have the user manual and technical manual of this trike/scooter please share
Post by jotrike2011 on Apr 9, 2012 13:07:16 GMT -6
Hello Kaka20 I sent the manual that I have email Jordi
Post by Alleyoop on Apr 9, 2012 14:11:41 GMT -6
Hey Jotrike2011, If you have a TRIKE manual send it to me as well I can put it in the MANUAL SECTION here as well. Alleyoop
Post by leenark on Apr 10, 2012 8:50:05 GMT -6
Alley: With such few miles on this guys trike there is no reason that stator should be burnt up...do you agree?? I would be very concerned about the electrical "regulation". I can certainly understand that if the stator is malfunctioning because of burnt wires it would cause engine reliability problems. What I don't understand (short of a factory defect in the stator) why the stator would burn up this quickly in the life of this particular scooter. It appears this particular stator was poorly made and with little or no quality control of it? A new one might fix the problem but I believe after a new one is added I would do a voltage check to see what it is putting to the battery and what it is absorbing. vr, Lee
Post by kaka20 on Apr 10, 2012 23:05:49 GMT -6
leenarkhow will i check the electrical regulation.. because in the past the problem started when one day on scooter was get totally wet in the rain and it was not starting.. the real stator plate is given in picture which they say is burnt Attachments:
Post by Alleyoop on Apr 11, 2012 0:17:40 GMT -6
Lee, Well that tells the story why it happened it got wet and shorted out and some of the coils got hit. Water usually causes trouble with these scoots and shorts out things. Mikes trike got rained on and it was his KEY switch that got all wet and it would not start, it was deader than a door nail. He had to dry it off and spray it with some stuff, and it started right up. I don't know what you could do to protect the stator from water. Alleyoop
Post by NoJoy on Apr 11, 2012 4:27:01 GMT -6
I would suspect more that water pooled on curcuit boards or in connectors than got into the stator, but again that is not so impossible either. It is definitly the result of shorting out though. A trash bag even if it's just over the handle bars where the majority if the electrical is when every there's even a hint of rain may have saved the day.
ed
Post by Alleyoop on Apr 11, 2012 13:10:13 GMT -6
Yep, you can get a cheap cover just as long as its waterprove throw that sucker on when your parking it for the night or day or when it looks like rain. Pretty cheap investment and saves you money, headaches, wrenching and you keep on riding. Alleyoop
Post by mike6736 on Apr 11, 2012 15:44:53 GMT -6
I hate them water probems. Mike was not the key and switch it was the connectors to the switch, water from the V section over the front drip down and you all know how the connectors are..next to nothing really. Had to clean and spray and wrap.
Mike
Post by leenark on Apr 12, 2012 8:16:23 GMT -6
This is all good to know. I don't drive the Magnum 300 or my CB 900 when it looks like rain (to old for that kind of fun). I think I told you guys about my digital volt meter I permanently mounted...probably in the "other forum" though. Anyway it provides me with a very good analysis of what is happening on the charging side of my system. I can switch it on before I ever fire up the scoot and it tells me the health of the battery before I crank it up. It's so reliable I know when I should put a slow charge on it long before I'm going for a ride. While I'm riding it shows about 14 volts of current going to the battery from the stator. It's comforting more than anything. ALLEY: My Honda 900 has a sealed stator...I haven't really looked at our scooters. No way to seal it?
Post by kaka20 on Apr 17, 2012 5:47:45 GMT -6
now scooter is running fine.. but when i apply brakes of back wheels . weird cranky sound is created. but when i apply the front wheel no sound is created. usually i use my scooter on weekend . all the week it stay off. does it need some oil or what. why sound in back brakes so weird/annoy like something is so dry.
