Post by kaka20 on Apr 17, 2012 5:47:45 GMT -6
now scooter is running fine.. but when i apply brakes of back wheels . weird cranky sound is created. but when i apply the front wheel no sound is created. usually i use my scooter on weekend . all the week it stay off. does it need some oil or what. why sound in back brakes so weird/annoy like something is so dry.
Post by kaka20 on Apr 10, 2012 23:05:49 GMT -6
leenarkhow will i check the electrical regulation.. because in the past the problem started when one day on scooter was get totally wet in the rain and it was not starting.. the real stator plate is given in picture which they say is burnt Attachments:
Post by kaka20 on Apr 9, 2012 3:09:13 GMT -6
if any one have the user manual and technical manual of this trike/scooter please share
Post by kaka20 on Apr 7, 2012 11:30:52 GMT -6
looks like this Attachments:
Post by kaka20 on Apr 7, 2012 11:21:46 GMT -6
today i take my trike to workshop they...checked..they opened the stator plate and tell me that it is burnt...the spring wraped around two coils where totally black in color..the above picture is not of the real stator plate but it looks same as in my trike... same happened in workshop after 10-15 minutes scooter stop starting even with a kick....they say we will fix it tomorow...i told him about checking the values but they say first scooter should pass current...then we will see the next problem... Attachments:
Post by kaka20 on Apr 6, 2012 23:56:54 GMT -6
my scooter runs only 860 km till now. now it start with a single push of button but runs very slow and does not pick up the speed and also the silencer back fire like a cracking firework.. and stops after 15 minutes and then it does not start whatever you do
so does the value adjustment will solve the problem
Post by kaka20 on Apr 6, 2012 11:51:35 GMT -6
in the manual the ""values clearance in 0.12 out 0.12"" after 1000 km distance
Post by kaka20 on Apr 5, 2012 6:31:45 GMT -6
you mean tunning....
Post by kaka20 on Apr 4, 2012 23:19:27 GMT -6
THIS IS THE TRIKE PICTURE Attachments:
Post by kaka20 on Apr 4, 2012 23:16:06 GMT -6
engine : GY6 200 CC
Post by kaka20 on Apr 4, 2012 23:15:10 GMT -6
i have a china made trike 200cc ( name: WJ200ST-6B) engine g6y type with reverse.
the problem is:
when it get started . it does not get the race/speed and after some time it stops after 15 minutes almost. then it does not start again.. i tried to start in in the night. then i left it. in the morning when i start it. it start at once.. and the result same.. it runs from almost 15-20 minutes and same problem not picking up the race .not exceding speed .
what could be the problem
Post by kaka20 on Jun 25, 2011 2:17:07 GMT -6
tried in every position but does not work
Post by kaka20 on Jun 21, 2011 12:07:26 GMT -6
this scooter is similar to Ice Bear PST150-11 / Roketa MC-102 150cc 3-Wheeler Trike if any one have the manual of this scooter then plz share.....
Post by kaka20 on Jun 21, 2011 12:05:30 GMT -6
yes i know, i have done that , push it down and then turn to left but not moving....
Post by kaka20 on Jun 20, 2011 23:27:51 GMT -6
the ignition key does not goes to lock position. it works fine on ON and OFF and also on opening the seat. but does not moves to lock position so the trike comes in lock position. it is a new scooter. what could be the problem and how to repair it. and also i need full diagram of scooter so could identify which part is located in which position. so get to know my trike Attachments:
