Post by dougar48 on Feb 24, 2013 22:19:01 GMT -6
I received a new carburetor the other day that I ordered from ebay. It is a KEI HIN CVK carburetor. When I opened it up I noticed that it did not have an accelerator pump. The casting did not have the location for the pump completed and no pump which seemed rather odd. Do you know what is going on Will this carb function on my 2011 TaoTao 50cc scooter?
Post by Alleyoop on Feb 24, 2013 22:41:05 GMT -6
Yes it will work just fine, there are two kinds of carbs ones that come with a pump and ones that do not have a pump. The ones with a pump sometimes cause troubles because if you twist the throttle enough it squirts more fuel into the venturi. Alleyoop
Post by dougar48 on Feb 25, 2013 17:13:32 GMT -6
All right! I thought as much but wanted to hear about it from someone that knows. Thanks Alleyoop! I'm new to this forum and this was my first post. This is a very cool site. dougar48
Post by Alleyoop on Feb 25, 2013 19:33:32 GMT -6
Your welcome if you need help tuning the carb I can tell you step by step how to do that. Alleyoop
Post by mojo50100 on Nov 16, 2013 17:44:03 GMT -6
I just got a new carb without a accelerator pump, how do I switch from my old one to the new?
Post by markwb on Nov 16, 2013 19:03:24 GMT -6
Remove old carb, install new carb, no further action required except maybe some minor tweeks.
Post by mojo50100 on Nov 16, 2013 19:45:36 GMT -6
I put the new carb on and got nothing
Post by redroush00 on Nov 16, 2013 19:49:46 GMT -6
Prime the fuel. Takes awhile if you have a petcock
Post by Alleyoop on Nov 16, 2013 19:57:45 GMT -6
If the carb is a CVK carb and it does not have an accelerator pump, IT has a ACV valve that requires VACUUM. Here is what your carb looks like without a pump, NOTICE you need a Vacuum hose going to the ACV valve. Alleyoop Here is MY OWN CARB connections:
Post by mojo50100 on Nov 16, 2013 20:12:18 GMT -6
Yeah! My carb looks just like that. So I hook the vacuum up to the mani and use a t for the fuel pump. Is that correct?
Post by Alleyoop on Nov 16, 2013 20:48:26 GMT -6
If you used a "T" then hook it up like mine is. Alleyoop
Post by mojo50100 on Nov 16, 2013 21:40:31 GMT -6
I'll do that tomorrow. Thanks! I'll let u know how it works
Post by mojo50100 on Nov 17, 2013 16:39:04 GMT -6
Thanks! It works, only problem is sometimes when I try to start it I need to prime it. I think maybe a bigger jet or lines, what do you think?
Post by Alleyoop on Nov 17, 2013 16:51:30 GMT -6
Post by mojo50100 on Nov 17, 2013 17:40:48 GMT -6
Thanks Again! You have been REAL HELPFUL! !..
