Vespa Specialist
Post by Kaveman on May 9, 2013 19:51:45 GMT -6
Vespa Specialist
Post by Kaveman on May 9, 2013 20:23:35 GMT -6
Post by jct842 on May 9, 2013 23:28:56 GMT -6
all worth while! and the ridin begins
Vespa Specialist
Post by Kaveman on May 10, 2013 15:12:04 GMT -6
Well . My scoot has a oil leak some where !! I'll have to pull the cowlings off this weekend to see if I can find it. Add the ruckus from the clutch (a/e may have to pull that to). Otherwise it runs well . Like with chinese scoots , its always something !! willc.
Vespa Specialist
Post by Kaveman on May 10, 2013 19:05:45 GMT -6
The oil loss is minimizing. I guess my scoot wanted to mark its spot !! I have made 2 clutch cable adjustments . The second may have taken care of the issue with the scoot wanting to move forward while the clutch lever was fully pressed . So far other than the oil leak and clutch cable adjustments , the scoot is behaving itself . I put the 1st gallon of fuel in tonight . That was after adding 2 cycle oil to the tank . Not sure what type of gas milage I'll be getting . Hopefully I'll know soon . Right now I need to focus in on getting the newly built engine broken in and being nice to it till that is done. That means no 45+mph rides. This has been quite an expierence for me and I have learned quite abit concerning the vespa 2 stroke engines both internally and externally. More updates will be posted as time goes along.. Have a great weekend to those who read this thread . willc. ;D p.s. It has been taking anywhere from 1 to 3 times with the kickstarter to get the engine started. No gripes from me on that !! ;D
Post by justbuggin on May 10, 2013 23:51:49 GMT -6
awlsome news hope you have lots of fun with it
Vespa Specialist
Post by Kaveman on May 27, 2013 20:20:38 GMT -6
Vespa Specialist
Post by Kaveman on May 27, 2013 20:55:55 GMT -6
Post by dragonsparks on May 28, 2013 13:00:13 GMT -6
The suspence is killing me. So which way did you go? Cool Thread. Dave ![](http://www.freesmileys.org/emoticons/emoticon-object-017.gif)
Vespa Specialist
Post by Kaveman on May 29, 2013 12:24:13 GMT -6
After reviewing the options available , I have decided to go with a new clutch assembly. Most likely from over seas shipped via FedEx . I'll get to order it next Monday (a/e Payday) . Then the wait begins . More to come as things progress ! willc.
Vespa Specialist
Post by Kaveman on Jun 27, 2013 14:49:43 GMT -6
Vespa Specialist
Post by Kaveman on Jul 13, 2013 14:26:40 GMT -6
Greetings my fellow Scootists !! Here is yet another update . The p200 powered Stella 2T is back on the road . I was able to get the new clutch installed on July 3rd . After a few clutch cable adjustments it was back to being ride able again . A new issue is bugging me at the moment. The scoot is hell to shift when first getting going. The clutch isn't the issue. Another scooter guru of another Vespa scooter related forum was kind enough to send me a used Paggio made shifter for my Paggio P200 crankcase . Up till this point I have been using the original shifter from the original LML made 150cc engine. Apparently there are a few little differences between the two crankcases when it comes to the shifter itself. To fix this I'll have to remove the old shifter ( a royal pain in the tuchas to do) then remove the 2 shifter cables ( dealing with those d@%* irritating pinch bolts from hell yet again ! ![:-X](//storage.proboards.com/3059616/images/KFYGmTZoeW9aIUUfv6Z7.gif) ) , installing the 2 cables onto the 'new" shifter ![:o](//storage.proboards.com/3059616/images/dfjqY_EkXQy5T3J77XO5.gif) , getting a gasket put between the shifter and crankcase ![:o](//storage.proboards.com/3059616/images/dfjqY_EkXQy5T3J77XO5.gif) then tightening the 2 retaining nuts and pray I did everything right the first time ! The joys of working on ones scooter ! ![:P](//storage.proboards.com/3059616/images/vLD_Xsl3B90qHN7AgMyd.gif) I'll try and get a couple of pics taken while I am doing this . Hopefully by the end of tomorrow I'll have the work done. I need to change the crankcase oil as well so this will be a good time to get that done. That's pretty much it for the moment ! willc. ;D ![](http://i435.photobucket.com/albums/qq72/shalom72c/p200_gear_selector.jpg)
