Post by luvmyscoot on Jun 4, 2013 16:24:41 GMT -6
Hello All,
Well it has been about a month or so since I was last here. My scoot is still acting funky!!
When last we spoke, it was running very fairly well (but rich) after installing a new kei-hin carb. Fast forward a bit; I rode it to work for about a week or more with no real problems it was running fast passing cars while slabbing it on the freeway.
One day after work decided to go for a little longer trip about one hour out of town in the boonies to enjoy cali spring weather. Ended up coming back on a tow truck!
(It could be battery leach, while sitting at work overnight, considering putting on batt kill switch). I always kept it on a little batt tender while at home.
Had plenty of fuel but fuel pump stopped running. (even after charging batt again) Little aftermarket one, all oem stuff cut off by po. Took fuel tank out of floor and mounted above carb added filter and now have a nice gravity fed fuel system. It gets plenty of fuel now.
Charged it and it ran good again, rode to mom’s house in the country by way of highway and good roads. No problem; left moms house because it was late and dark, so I took short cut (rough country roads pot holes etc. Muffler fell off!!!!
When I got to my exit and could hear over roar of wind that muffler was disconnected (still hanging on by a thread). Bike would not stay running at idle.
Re connected muffler with better clamp (one of the nuts was stripped). Now it will run under throttle but cuts out and feels like dying at just above ide to 1900 rpm. Hesitates/ dies under low power, roars at WOT.
Now! Bike is completely pulled apart again on the garage floor. Since apart I just re did the valve clearance; set to 004 top and 006 bottom after finding tdc. Bottom was 005 when I re adjusted (still ok I think but website said set at 006) .001 is not a very large gap difference.
The instrument cluster plastic housing (plastic box) was crumbling from heat of cdi or rectifier or both or just age (IDK?). Since apart I fabricated a new housing box out of tin flashing.
Now all gages are secured and cluster looks much better.
Gages all seem to work (no actual connections or fusible links touching metal to short out) Lights are all now in the proper places instruments light up properly.
Wrapped new box in duct tape to try to waterproof seams a little. (I can buy a new one but I am hesitant to spend any more big money on this thing until sure it is going to run).
Pulled plug: Bike is running rich as hell. I have tried adjusting A/F mix and idle. I cannot get it to smooth out.
Must be vacuum/ fuel (but seriously po has cut almost everything off and there is really no vac lines running to anything any longer).
One vac from intake maniforld to egr. I plugged egr where it comes out of larger port. With a hose and a large bolt. No leaks there.
One big hose comes off of timing chain cover (round bowl shaped thing covering small bicycle chain). Where does this go? Should this be a vent or connected to something? Steam/ heat comes out when running. No noticeable change in running when hose is plugged by thumb. Should I leave open or plug as well?
Carb bowl has little L shapped vent hose. That’s about it.
No air box any longer so vac lines running to it. No charcoal smog crap any longer either.
Radiator has leak, while apart going to have that fixed as well. Just found leak behind water pump. Going to take off and see if damaged or gasket bad or something.
I cannot believe all this is because of the muffler falling off. Sorry about the long post. I tried to break it up into manageable sections so you all can digest it all.
Thanks again
Dave
P.S. cooling system is still apart so I cannot start bike yet to see if valve job fixed or not. Any ideas at all fellas?
Thanks again
Dave
