Post by Steve on Jun 8, 2013 13:38:26 GMT -6
Greetings & Sallytashunz! I think the PAIR system is all gone. Here is what I took off. I believe the PAIR system has been completely removed, correct? I even blocked the feed to the exhaust. I know - fantastic! :-) Are there other ports/parts to be blocked/plugged/removed? Thanks, in advance!! < Steve >
Post by Alleyoop on Jun 8, 2013 19:03:21 GMT -6
GOOD JOB, Yep there are just three plugs the NCY metal plate, the hose connected to on the air box or tubing and the vacuum by the manifold(DONE DONE). Alleyoop
Post by Steve on Jun 8, 2013 20:35:07 GMT -6
Thanks!
Just to be sure you understood me correctly...
I only added the NCY plate, nothing else. No plugs, nada.
Is that all I need to do?
< Steve >
Post by Alleyoop on Jun 8, 2013 21:05:15 GMT -6
You need to plug up where I labeled it 1. The Vacuum Connector on the MANIFOLE. 2. The Connector on the AIR BOX where the hose from the Canister was plugged into. THEN YOUR DONE DONE ;D
Post by Steve on Jun 8, 2013 22:52:01 GMT -6
Thanks, Alleyoop. I plugged the one on the right when I removed the EVAP. The blue plug is new tonight. Tomorrow? Put on the farings and RIDE!! Thank you so much for your help! < Steve >
Post by Alleyoop on Jun 9, 2013 11:36:20 GMT -6
VERY NICE AND NEAT!! GREAT WORK. Where did you get those plugs those are great!!! Alleyoop
Post by Steve on Jun 9, 2013 12:22:45 GMT -6
Post by royldoc on Jun 9, 2013 16:54:05 GMT -6
I Have a kit with various size plugs. They are vacu tight brand. I think I got them at auto zone or o reillys. A 30 pack with 5 of each 5/32", 3/16", 7/32", 1/4", 5/16, and 3/8". they are all black, I like the color coded. I didn't use zip ties though, it's a good idea.
Roy
Post by Steve on Jun 10, 2013 21:56:39 GMT -6
Alleyoop and all, REALLY appreciate your patience and directions. I went for my first real pleasure ride today (on my scooter ). I went almost 23 miles. I could not have done it without your help. Again, thank you very much!! < Steve > PS - Know where I can get a softer seat?
Post by Alleyoop on Jun 10, 2013 22:29:20 GMT -6
Good to hear, you are enjoying the scoot, as for the seats you either have to repack one yourself or take it to an upholstery place to have them make it comfy. Alleyoop
