Post by Steve on Jun 14, 2013 18:50:10 GMT -6
Occasionally, I have to maneuver the key in the ignition to get it to the position that the lights would come on so I could start it. That was then. Now, I can't even get the lights to come on. The wires to/from the ignition appear to be fine. Are the ignitions touchy? Is there an adjustment within the ignition that needs to be tightened? Or is it usually a culprit? Thanks!! I have been riding it. I've put almost 300 miles on it!! ;D < Steve >
Post by jjoshua20213 on Jun 15, 2013 2:51:18 GMT -6
My ignition broke on mine. like the key turned but no lights. I had to pop open the ignition and turn the piece the key shouldve manually.
Post by case on Jun 15, 2013 7:11:30 GMT -6
You can unplug and plug in a different one to test, but if it has a diode inside the ignition and it has fouled out, it can be broken into and fixed . good luck i hate electrical problems lol
Post by Steve on Jun 20, 2013 20:40:41 GMT -6
TADA!!! Fixed it. ;D
I took the electrical part off of the mechanical part of the ignition. I noticed that only two of the three catches were fully "caught".
I disassembled the piece, cleaned the contacts (with sandpaper), and reassembled. This time, I ensured all three of the catches were caught.
It has worked EVERY TIME! ;D
Thanks for your assistance and comments.
< Steve >
Post by Alleyoop on Jun 20, 2013 20:46:45 GMT -6
FANTASTIC!! Good job, most would have just bought a new ignition Alleyoop
Post by jct842 on Jun 20, 2013 22:02:36 GMT -6
You might take a look see to find a new ign switch so you know where to get one and how much. If it did it once it will probably do it some more and you can only take that kind of stuff apart a few times before it can't be put back together again.
Post by Steve on Jun 21, 2013 9:17:12 GMT -6
Thanks. Appreciate the info. I think it'll be good for a while. The unit was not snapped together completely. I bought the scooter after it had been dropped. I've done A LOT of maintenance/repair on it. It only had 23 miles on it - it now has 338 miles!
