Post by retardninja on Jun 30, 2013 14:10:25 GMT -6
I guess the first stupid question I have is do I need to completely remove the muffler in order to take off the the cylinder head? cuz that's what's about to happen unless somebody speaks up real fast....
Post by Alleyoop on Jun 30, 2013 14:20:49 GMT -6
Not the muffler BUT YOU DO need to disconnect the PIPE(FLANGE) bolted to the EXHAUST MOTOR HEAD. Alleyoop
Post by retardninja on Jun 30, 2013 15:21:54 GMT -6
I think just maybe I found the problem. Kinda skeptical but just maybe. I'm no photographer but this isn't a photography contest either. I've never been so relieved to find something broken. Attachments:![](//storage.proboards.com/3059616/thumbnailer/sg72yYYokjC7g2W26IGL.jpg)
Post by Alleyoop on Jun 30, 2013 15:28:21 GMT -6
Yep you found it. Alleyoop
Post by retardninja on Jun 30, 2013 18:22:39 GMT -6
Okay it's all back together up to where I need to do the valve adjustments. But when I turn turn the magneto by hand it seems as if it is catching or locked against something inside and it won't turn anymore. Is this normal or should I take it apart? I'm scared to screw it up after all this.
Post by Alleyoop on Jun 30, 2013 18:26:42 GMT -6
take the plug out and see if it will then turn easy. If it still does not want to turn then something is binding. By the way what all new did you put in? Alleyoop
Post by retardninja on Jun 30, 2013 18:52:15 GMT -6
new piston, rings, circlips, gaskets and two new big aluminum things that go onto the block, but not valve cover. Do you think that the chain came off the rear sprocket inside the main part of the motor?(is that the block?) I thought I did everything right but the chain was being a pain in the arse. how do I check the chains rear sprocket?
Post by case on Jul 5, 2013 20:39:18 GMT -6
Tke the head back off. Then remove your plastic fan cover on right side (dur) then grab the chain with right hand and move the piston by turning the fan attached to the motor with the left hand. If the rear gear is attached to the chain it will move in your hand correctly. If the chain does not move when you rotate the engine or it moves weirdly, you will have to reattach it man ![;)](//storage.proboards.com/3059616/images/io3qXvKuAKgoS3GBNHWG.gif)
Post by jjoshua20213 on Jul 5, 2013 21:36:16 GMT -6
Post by retardninja on Jul 6, 2013 7:59:18 GMT -6
Yeah thanks case. That is exactly what I did. SO at least that part is done.
I did buy my bbk off ebay for $54. Good seller, very quick shipment, very helpful.
Post by jjoshua20213 on Jul 6, 2013 19:59:06 GMT -6
Cool, i'm glad you found it. You in for a treat when your done.
