Certified Clinician
Post by retardninja on Nov 14, 2015 14:11:51 GMT -6
Okay thank you Alleyoop Ill go do it now.
Certified Clinician
Post by retardninja on Nov 14, 2015 13:28:31 GMT -6
I guess the real problem is I don't know what Im looking for.Do I have to take the wire harness off and inspect every wire? Why would this just have suddenly happened?
Certified Clinician
Post by retardninja on Nov 13, 2015 13:49:03 GMT -6
Cyborg, So maybe just tape it up and try again?
Certified Clinician
Post by retardninja on Nov 13, 2015 9:29:05 GMT -6
I charged up my battery for my taotao and connected it in the normal way, both reds to the positive, and the black to negative. I bumbled around for a couple of minutes, and was startled to see smoked rolling up from my red wires on the positive post. I took them off as fast as I could, but they are scorched, especially the one with the fuse. When I oped the fuse box, both metal ends were detached from the glass tube.
Why would this have happened? I appreciate the input. I need to fix this but I dont want it breaking over and over again.
Certified Clinician
Post by retardninja on Jul 24, 2015 11:31:29 GMT -6
Thanks guys. I'll just buy a new carb and use this until it gets here.
Certified Clinician
Post by retardninja on Jul 24, 2015 9:17:17 GMT -6
Hi. I just replaced a carburetor on my gy6. The stock one was impossible to open so I used a high performance carb that I had laying around, which I bought to go with an 80cc big bore kit for another scooter. Anyways, this scooter in question does not have a big bore kit, just a fancier carb. It runs good, but it is using fuel like crazy. I went 10 miles and it went from nearly full to nearly empty. Ive checked for leaks, and there are none. When I took the carb off to check my fuel lines, i found that all kinds of unburned fuel was in the big hose coming off the back of the carburetor. Is there anything I can do about this, other than buying yet another carburetor? Thanks for checking out my post.
Certified Clinician
Post by retardninja on May 25, 2015 10:07:39 GMT -6
This is a simple thing that I forgot how to do. I have a full tank and the gas has sat here since last October. It wouldn't start before its long set out in the weather, so I just bought another carb and put it on. The only thing I remember is sucking the vacuum tube will release gas. No fuel comes when I have the fuel line disconnected and try to crank it, but the fuel filter itself doesn't seem to be clogged.I can blow freely through it in both directions. So I'm going with first things first and replacing the gas. Has good compression and spark.
I would really appreciate the easy way to drain gas to get me started please. Thanks.
Certified Clinician
Post by retardninja on Sept 17, 2014 13:06:26 GMT -6
So Advanced Auto carries it. The guy just told me not to soak my carbeurator in carb cleaner because it will swell the rubber rings. I have never heard that before (to not soak it). I also went to Seafoams website and there is a testimonial where some guy says he soaked his carb IN SEAFOAM. Ive cleaned and rebuilt carbs before, but now I don't know what to think. How should I use the seafoam (just add it to the gas?)and should I not soak the carb? I can't see all those little ports getting clean without soaking it for at least a few hours.
Certified Clinician
Post by retardninja on Sept 17, 2014 12:43:28 GMT -6
I have the AA Big Book (and a 9 month chip) I'll run to the store for the other stuff as soon as I can. What does the Seafoam stuff do and will Auto Zone carry it? Thanks for the direction.
Certified Clinician
Post by retardninja on Sept 17, 2014 12:11:01 GMT -6
Hello all. Last winter I drove my scooter to work early in the morning, it was cold as hell out. After 9 or 10 hours it was even colder weather, and the scooter would not start for anything. Since then I took an unfortunate vacation, courtesy of the state, and I still can't get it to start. I checked the spark plug and it was fouled, so I cleaned it. When I tested it I got a pretty good jolt ripping through my hand, but it still didn't start. I checked my valves and the cold had closed them up tight. I set the top to .003 and the bottom to .004 (I made sure it was all lined up).It still won't start and I'm worried that I will kill the battery if I keep trying. I can see fuel in the filter. I thought perhaps it might be a fuel delivery problem, but I'm not really sure Any suggestions? I know I am forgetting something I once knew to do, so reminders are needed.... (I'm on house arrest so if I get permission to go to the store, I can only do it once. Please list anything possible you think I may need to pick up).
Thanks.
Certified Clinician
Post by retardninja on Aug 25, 2013 17:51:10 GMT -6
It does start for one fire, and then it dies. I' m so close after all this time. I amm so happy! What next?
Certified Clinician
Post by retardninja on Aug 24, 2013 19:56:44 GMT -6
Hi Alleyoop. It still wont start and there is gas in the fuel filter. So I I don't know whats next. I have the top valve set at .03 and the bottom at .04
Certified Clinician
Post by retardninja on Aug 24, 2013 15:36:09 GMT -6
Hello. I have finally got this scooter to fire with quick start but it wont actually run. There is fuel in the fuel filter and I am really close. I'm still not convinced I have the fuel lines hooked up correctly. Here is how I have my fuel lines running. The first image is how I was told to hook it up. The second is how I originally had it. I am so close please dont blow me off!!! This has taken 3 months.
Certified Clinician
Post by retardninja on Jul 21, 2013 13:58:19 GMT -6
Here is the video. I just cant see that I am doing anything wrong...
Certified Clinician
Post by retardninja on Jul 21, 2013 13:46:37 GMT -6
I am working on uploading a video of the timing set up I have done. I was going to use a Dremel and relieve the obstructing points shown in this drawing Attachments:
